Question about Yamaha CDM-900 110-Disc CD Changer
The CDM-900 mechanism has trouble loading CDs
The CDM-900 mechanism has trouble loading and playing a disc. It cycles several times, sometimes producing a loud "bang" as the CD is moved from playing position to storage position. A scratch has appeared on one CD which was new, causing a skip sometimes.
4 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: 3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Posted on Jun 26, 2008
  • 85 Answers
SOURCE: Skipping all CDs
Laser is duff uses the old sony kss family i believe,easy to change and get on ebay..
Posted on Jan 08, 2009
technical114
  • 1851 Answers
SOURCE: Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Posted on Feb 21, 2010
Has anyone cleared JAM form a Teac PD-X100 compact disc changer
You either have a broken part in the loading mechanism or the belt for the loading mechanism is off or stretched. Remove the chassis covers and inspect it.
Sep 05, 2016 | Audio Players & Recorders
DVD CD player will not work. Door will not open to play DVDs or CDs or MP3 player
Disc loading mechanism fault. A broken loading belt or a gear wheel can cause this. Contact any service technician. The loading mechanism have to taken our from the device, for repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 19, 2016 | RCA RTD209 System
My Alpine cd receiver CDA 7837 wont play any music discs i burn. ive tried using nero which automatically converts them to cda but it wont play them it just ejects the disc. it works when i put it in my...
You may want to try a different brand of blank cds. I had an alpine that would not play sony white label cds, but played most everything else.
Aug 30, 2011 | Alpine CDM-7833
It wont play brand new burned cds
What brand of bland cds are you using? Maybe you can try a different brand. I know Alpine has trouble reading some brands of blank cds, such as sony.
Aug 10, 2011 | Alpine CDM-9803 CD Player
Jvc ch-x350 12 disc cd changer. Loads cd but will not play it. reads: no disc and moves to the next cd and repeats. ??
If you are inserting non original cds, cds you make from your pc or cd copies sometimes they dont read, another reason is to make sure that you are inserting the disk with the correct side up, it will show you in the cd changer magazine slots. If none of this solves your problem then you have a defective cd mechanism and you need to replace or repair the changer. Very common problem with JVC Cd Changers, I used to replace them all the time and they tend to skip alot as well, get yourself a Pioneer if money is ok if not then follow my steps.
Good luck and dont forget to rate and vote for me if I helped you.
Thanks.
Jun 13, 2010 | JVC CH-X350 12-Disc CD Changer
DVP-NC85H - - Shuffle play among several CDs
You should refer to your Product's Operation Manual for help on this. Also, you may goto www.sony.com for more info.
Apr 29, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
My Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Dec 19, 2007 | Pioneer PD-F407 25-Disc CD Changer
How to set the time on alpine cdm 7833
I found the users guide on Alpine-usa.com
The manual is for several models, the CDM-7833 is one of them.
It is her if you would like a copy;
http://vault.alpine-usa.com/products/documents/OM_CDA-7837.PDF
To set the time;
Press and hold CLK button for 3 seconds
While flashing, use the H and M buttons to adjust the time setting(s).
The time will be saved 5 seconds after a button is pressed.
Best of Luck
Oct 31, 2007 | Alpine CDM-7833
Bad disc
I have the same problem with some of the Discs I have burned. Most people say the power supply, but I have 2 of these units so I swapped the power supply to see if that was it. The problem stayed in the one machine, ruling out the power supply.
Aug 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Yamaha CDM-900 110-Disc CD Changer Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
