Dead screen on about 5 different monitor usually happens after a power outage. The monitors still have the power light but no display but if you look closely the monitor blinks like it wants to come on. I dunno.
  • 151 Answers
If there is eht in monitor then check video section of monitor.this section is placed on crt.check video amp. ic and vga cable.check incoming wires of vga cable and components related with it.And check driver transistors of rgb.if there is no eht in monitor then change horizantal output transistor that is place onhitsink of eht. big in size.Hope is will help you.i am always here for you
Posted on Mar 25, 2008
SOURCE:
Why is my motorola baby monitor now displaying everything upside down and backwards after a power outage?
Hope the monitor is not placed upside down. Just joking.
The power outage must have interfered with the control and signals. Best to try the reset and registration process described on page 17 of user guide under help.
http://www.motorola.com/on/demandware.static/Sites-Site/Sites-Motorola_US-Library/default/v1337848113914/All-Products/Baby-Monitors/MBP36/MBP36-UserGuide-ENGLISH.pdf?version=1,337,867,943,000
Aug 26, 2014 | Motorola Mobility MBP36 3.5" LCD Digital...
Why going off after 5-10 min black screen
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 04, 2014 | Gateway 24" Widescreen Flat Panel TFT LCD...
M93p suddenly the screen goes black screen
Good luck
Jun 19, 2014 | Lenovo M93P Tiny I7-4765T 8GB 500 WIN7/8
SAMSUNG TMS22WS Flickering Picture
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Computers & Internet
BOUNCING CHARACTERS/DISPLAY
Mar 22, 2014 | AOC 19" LED Monitor e950Swn Black
Screen scrambles
Jan 05, 2014 | ViewSonic VX900 19" LCD Monitor
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
Problems After Power Outage
Sounds like the power outage damaged the video interface could be damaged. You might have had a spike that effected the red input of the monitor. You can try to order a video interface, or like I suggest to others, look for the same monitor but broken on ebay and swap out the interface board. Chances are this will fix your problem. Good luck
Oct 02, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Open Questions:
Computers & Internet Logo
37 people viewed this question
Ekse
Alun Cox
