Question about Quinny Buzz Jogger
Where can i find cheap parts for my quinny buzz pushchair? One of the plastic covers has come off the button you press to collapse the chassis.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
You might want to go to the site It might not be too expensive for that part. http://quinnybaby.com/info_replacement_parts.asp Click on the link. I hope you get the part you are missing.
Thank you
Posted on Apr 30, 2010
Does the quinny dreami fit onto the maxi-cosi loola pushchair? If so is the same adaptors that would be used for the maxi-cosi car seat?
Hi
No the Quinny Dreami is not compatible with any Maxi Cosi chassis.
The Quinny Dreami can only be used safely with Quinny Buzz or Quinny Speedi chassis.
For the Maxi Cosi Loola chassis you should use the Maxi Cosi carrycot only.
Nov 05, 2012 | Quinny Dreami Buzz Bassinet Juice Carriage...
Remove the quinny seat from the base, then collapse the base
Good Afternoon
On either side of the Buzz seat there is two catches; you use these catches to recline the seat unit to the required angle. Push them both down and it unlocks the seat - Lift the seat toward you and it will come off the chassis.
To collapse the unit down, its easiest to do so when you're standing in front of it. On the left side knuckle is a button you need to push down: On the right side is another button with arrows on it which you need to push and bring toward you. With your hands on these buttons bring the weight of the Buzz toward you and angle toward the floor, and it will slide into the collapsed position. Ensure the transport lock is on before travelling with it collapsed.
May 27, 2011 | Quinny Buzz Three Wheel Stroller
How to open and close quinny buzz pushchairs
If you lock the front wheel and lower the handle bar to the lowest postition first, this will make the chassis as small as it can be. Remove the seat/car seat or carry cot if this is on the chassis.
Then, stand in front of the chassis, with the front wheel between your legs.
Push down the grey rectangle button on the left hand side, then pull toward you the right hand rectangular button then push this button downwards,
Then, withnthe two buttons still pushed in, with your full body weight, push the chassis downwards the floor until fully folded.
I hope this helps.
Feb 18, 2010 | Quinny Buzz Three Wheel Stroller
How to I collase a quinny speedi sx pushchair
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know. HTH
Feb 03, 2010 | Quinny Buzz Jogger
My quinny buzz is collapsing , can somebody tell me where can i buy a new frame maybe and spare wheels
alot of people on ebay sell spare frames and wheels. I had similar problem when mine kept collapsing. I had to open it then pull the part that slides up the chassis stem up a bit further till the 2 black plastic parts clicked into place.
Jul 03, 2009 | Quinny Buzz Three Wheel Stroller
Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
May 18, 2009 | Quinny Buzz Jogger
Where can i get my quinny buzz pushchair repaired?
Try contacting Quinny directly through their parent company www.dorel.co.uk The website has phone numbers and an email contact
Apr 08, 2009 | Quinny Buzz Jogger
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
Apr 25, 2008 | Quinny Buzz Jogger
Quinny Buzz Jogger Logo
563 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
