Question about Navigon 2100 Max Portable GPS System
I plug my Navigon 43 max series into computer and unit with usb cable. Kick up Navigon fresh and the software cannot find my unit. I have swapped ports and leads and still no joy. Can anyone help!
4 Suggested Answers
SOURCE: plug in car charger and it shows navigon connected to computer
some chargers will not work i think somwthing to do with a micro chip in it.
Posted on Jan 05, 2009
SOURCE: Navigon 2100 - need to open the case to replace
To open the case you will need a very small flat screw driver to pop off the back of the case (be very careful as the clips holding it together are very small). You will then have four small phillip screws to remove, so that you can remove the front of the case. To remove the circuit board, there will be two very small phillip screws holding it in place once you've remove the front case.
Posted on Oct 26, 2009
  • 11800 Answers
SOURCE: Hello. Left my Navigon 2100 (Canada 310) plugged
In your unit the default map is embedded in the operating system / firmware - its files aren't accessible thru the USB connection, which gives access only to the files on the SD card. If the map is still missing after the update then the defect is hardware - the memory chip that stores the map is defective. This is unfixable since the cost of the repair would be higher than for a whole new unit.
Your only hope to make it work is to get a new map from here
http://www.navigon.com/portal/int/karten_services/freshmaps.html
load it in a new 2GB SD card that will be used for it and only it and then configure the unit to use it: Option, Settings, Current Map.
Posted on Jun 24, 2011
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
It only shows Restoring factory settings and cannot switch it on or off
With the help of NAVIGON Fresh you can reinstall the software and thus return the device to the factory state. This can be necessary when the device does not work properly anymore or when the software freezes, crashes or otherwise does not behave as intended.
Please be advised that after reinstallation your saved data and favorites will be deleted. After reinstallation a software update or reinstallation of maps can be neccessary as well.
In order to reinstall the software and return the device to the factory state follow the steps detailed below:
1. Check if your device is on the compatibility list for the device restore
process.
2. Charge your device fully with the car or home charger.
3. Connect it via USB cable directly to your PC and turn it on.
4. Start the NAVIGON Fresh program and log in to your account with your
email address and password.
If NAVIGON Fresh is not installed on your PC, you can download the
software here.
5. Go to the menu bar at the top window border and click on
"My Navigon Device" and "Restore Device".
6. If NAVIGON Fresh does not recognize your device, please contact the
service center.
7. Follow the instructions and choose the device which you want to restore.
8. When the wizard has lead you through all the steps, click "next" to
begin the device restore.
9. As soon as the device restore has successfully finished, check for
updates for your device and install them.
Jun 03, 2011 | Navigon GPS
How do I give my brand new Navigon 3300 a good overnight charge
if you have a pc, you can use the usb to mini jack and it will charge
Mar 09, 2010 | Navigon 3300 Max Car GPS Receiver
Navigon 2100 freezes when plugged in
sounds like you have the wrong charger did you buy a non gen one? you can charge it from the pc with mini usb lead, but will show the same screen
Dec 06, 2009 | GPS
I can't get the down load for the Lexmark x1240 to work. I have down loaded it but when I try to get the computer to recognize the printer, it doesn't or it doesn't let it connect
Did the drivers install completely?
If so, try plugging the printer USB cable in a different USB socket, one that you did not plug the printer into before. If you don't have a "fresh" free USB socket, you can always swap plugs with the mouse for example.
Te computer should discover your printer and use the already installed driver.
If the driver did not install at all, try installing it again with the printer unplugged from USB, and plug it in to a "fresh" USB socket (as described above) only when asked to by the installer software.
Nov 22, 2009 | Lexmark X1240 All-In-One InkJet Printer
Can I get a usre maunal for mey new Navigon 33 or 43 please?
http://faq.navigon.com/opencms/common/Download/Manual/PNA/Navigon43xx/English_manual.pdf
Oct 11, 2009 | Navigon 4300t Max Car GPS Receiver
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
I HAVE A MESSAGE ON MY 2100 GPS,SAYS MN6 .EXE HAS PERFORMED AN IL
Sounds as if the system software that runs the GPS has been corrupted. Your device should have come with a CD that has software that can be reloaded or a utility that can be installed on the PC that connects to the navigon website to download and install the software for you.
Might want to start with that.
Hope this helps
TankMurdock
Apr 24, 2009 | Navigon 2100 Max Portable GPS System
Connecting computer to navigon 7100
You need usb cable and fresh software. download from navigonusa.com
Mar 09, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 2100 Max Portable GPS System Logo
448 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
