Question about Garmin GPSMAP 198C GPS Receiver
My Garmin 198C will not acquire satellitte's I
My Garmin 198C will not acquire satellitte's I get a message antenna output shorted. Any suggestions
zeusfaber
  • 247 Answers
SOURCE: No power
Could be worth a look at the connector on the back of the unit itself. As I discovered a few weeks back, they aren't as saltwater resistant as the IP67 rating would lead you to expect. Compare the pins in the plug with the diagram on page 99 of your manual (also downloadable from http://www8.garmin.com/manuals/GPSMAP198CSounder_OwnersManual.pdf) and make sure all the pins that are supposed to be there actually are. In particular, make sure pin 15 is in a decent state. This one carries power to the unit, but will act as a sacrificial anode in the presence of saltwater, and can rapidly corrode to oblivion. If this is what has happened, you have a bit of a problem, because Garmin, don't appear to be very good at making spares available. I was lucky in that the GPS I was fixing was a lower end model that only used five of the seven pins in its connector, so I was able to rewire to provide a supply through the unused pins. The diagram suggests that the 198C also sports a few unused pins, so you may well be in luck. A.
Posted on Apr 14, 2007
reef runner
  • 7 Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin 350 not acquiring - solved
This is a common problem. Even though the wire gave you reception, you still have a bad part in your GPS. Please see this link for more detail:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Dec 23, 2009
SOURCE: Acquiring satellittes function is not working
Try updating the chip set at the garmin website, this worked for me...
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00447-00&cID=160&pID=331
Posted on May 29, 2010
  • 3287 Answers
SOURCE: Unit began posting a message
Make sure the device's internal batteries are charged - or connect to the car charger. If the unit will not turn on, connect via USB cable to your computer's USB port overnight, before trying again.
With a clear view of the southern sky (in other words: not indoors, under heavy foliage, or between tall buildings), turn the nuvi ON. It can take anywhere between 1 and 2 minutes for the nuvi to get a "fix" from a cold start like this. It is best to be stationary to get the fix if having difficulty. It is not uncommon for the nuvi to take up to 20 minutes to get its very first fix (since leaving the factory). After that, a fix may be had sometimes in as little as 30 seconds.
please rate this reply if found to be helpful - good luck!
Posted on Jul 08, 2010
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
Satellites no longer acquireable
both the problems could be there mostly the chip corrupted.
Aug 29, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin not receiving satellites
hmmm...did you check for the latest firmware, by chance?
Feb 29, 2008 | Garmin StreetPilot 7200 GPS Receiver
- Jim
Oct 24, 2009 | Garmin nuvi 350 GPS Receiver
Antenna input shorted
contact garmin sounds like a defective unit
Mar 10, 2009 | Garmin GPSMAP 172C GPS Receiver
Garmin 680 -cannot acquire satellites
If a factory reset does not work, your antenna will need to be replaced.
- Jim
Oct 28, 2008 | Garmin Nuvi 660 GPS Receiver
Satellite unacquireable.
never buy magellan there junk lol and the problem you are having is a broken flip out antenna on the back of your unit ..it is common with the older flip antennas just buy a external antenna from garmin and fixed .......if not send it back to garmin because its hardware is bad
Aug 23, 2008 | Garmin Nuvi 660 GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
No power
Apr 14, 2007 | Garmin GPSMAP 198C GPS Receiver
Garmin GPSMAP 198C GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
