Question about Canon FAX-L250
HOW TO TURN OFF THE RING TONE OR TURN DOWN THE VOLUME
  • 385 Answers
Press Function and scroll to User setting with the right arrow(Nr 10 and 12 on the right hand side)and press start!Scroll to volume control and press start and u will be able to set it there!Just press start after setting each one you want!Good Luck!
Posted on May 05, 2010
  • mmohrcurry Nov 09, 2010
    for other Canon styles - go to menu - Fax settings and scroll til you find ringer volume
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Change ring tone
Go to settings sound to change volumes. Under ringtone in same previous screen you can change
Jan 27, 2015 | Cell Phones
WHY WON'T MY US CELLULAR S5 RING on INCOMING CALLS??
Is the volume up? Download Zedge, look for a decent ring tone and set it as default ring tone. Try now. If it still doesn't work, go to settings, volume and make sure that is all the way up.
Oct 22, 2014 | Cell Phones
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
We have an older Uniden cordless telephone-Model #EXI7960 that seems to have a very soft ring tone. How can we increase the volume of the ring? Also, is there an owners manual on-line for download?
The EXI7960 has two ring tones and two volume settings available. With the handset in standby, press the Volume up button. (The volume up and down arrows let you switch both volume and ring tone. So you may have to press it a few times to adjust the volume.) The display should show the changes.
Retrevo has the manual here: http://www.retrevo.com/support/Uniden-EXI7960-Telephones-manual/id/471dj498/t/2/ . You will need to enter a code to access the PDF.
I hope this helps.
May 27, 2011 | Uniden EXI 7960 Cordless Phone (EXI7960)
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Panasonic kx-tg2303 how do I change the ring tone?
With the phone off press the volume up and down button to ensure which ring tome you have. the up and down keys will change the volume. Now, press each of the keys 1 through 9 to select the ring tone you would like. Please let each ring tone finish before selecting a different one else the one you select next will not ring to let you know what it is.
cheers
Jun 08, 2010 | Panasonic KX-TG2303B/WH Digital Cordless...
How do I turn down the ringer volume on my HP 6210 Officejet
follow the ff. steps:
  1. press set-up
  2. press 4 and then press 6 (this selects BASIC FAX SET-UP and then RING,BEEP and VOLUME)
  3. press right arrow key to select one of the options:SOFT,LOUD and OFF (NOTE: if you are going to select OFF no will not hear dial tone,fax tone and incoming ring tones)
  4. press OK....
try this steps and give me feedback....*mrbench87*
Aug 25, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Ring Tone
if you want to make it silent hold down the hash key. ifnot then you may have to turn the volume of the ringtone down to 0.
Jul 15, 2008 | GE 2-9438C Corded Phone
Ring tone volume
to turn up the ring volume on the blackjack, there are two on the left hand side above the ear/charger port a UP & DOWN. those i use to adjusted my volume.
Dec 20, 2007 | Samsung Blackjack SGH-I607 Smartphone
Canon FAX-L250 Logo
169 people viewed this question
old marine
old marine
