Question about Samsung Jet S8000 Cell Phone
Samsung Jet Cell Phone is "dead"
The phone got wet when I was caught in the rain yesterday. dried it off OK, opened it up and found no visible water ingress. Phone was not working other than showing the main screensaver. The battery indicated flat so I put it on charge overnight. This morning the battery showed one bar less than full charge. I took it off charge and tried to activate it but it went onto a red & blue screen telling me it was "in Download Mode" I could do nothing to change this. Eventually I removed the battery, and replaced it after 5 minutes. Phone then switched ON with the CALL-END button, but went immediately to "Download Mode" Tried to access it via PC Studio, but only managed to upload the firmware upgrade. Same problem exists after the upload. I put the phoner back on charge for three hours, and it is now warm but DEAD...
It is still under warranty.
Help, please.
  • ransomsathom Apr 30, 2010
    When charging the battery, the phone and battery get warm, which never happened before now. The battery voltage is only 3V which I am sure is considered to be FLAT. However, I have no other method of charging the battery than via the phone and its charger. Is there a HARD RESET button on this device?
    Help gratefully accepted...
  • 567 Answers
Under warranty will not count on liquid damage if you take the battery out you will see a red dot that tells you water damage i have dried out some mobiles take out battery and sim leave on warm radiator couple of days then try again if still the same then it spares cost way too much to put right needs mother board ,and connectors hope this helps
Posted on May 11, 2010
    New Friend:
  • 180 Answers
If you its under warranty i dont think they will take it because of being wet but i would call them.. also i would take a hair dryer a try to dry it out very good once the mother board gets wet not a lot you can do.. i am sorry that i cant just tell you how to fix because realy nothing you can do..
Posted on Apr 30, 2010
Testimonial: "Thanks for that. Phone is alive but "dead" in appearance. Seems to be an issue with charging battery - down to 3V - water marker on Battery OK"
My samsung smooth got wet i let it dry but will not turn on
Wet Cell Phone
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Jul 08, 2012 | Samsung Cell Phones
Phone got wet in the rain today, now it wont switch on
Hi! You have to go to a service. Anyway, for future, if you get you`r phone wet, remove your battery in that moment and keep the phone in a hot place until it`s dry.
Dec 12, 2009 | Samsung Jet S8000 Cell Phone
Moisture from hot tub got under the touch screen of my cell phone, and now it's not responsive to touch. Is there anything I can do?
When most cell phones get wet or aquire moisture the circuit boards on the inside rust as they dry out so if the phone is insured I woudl just suggest replacing it because the rust on the inside will continue to affect the phone even after it is dried out. Depending on who your carrier is you maybe able to have a tech open up the phone and clean the circuit board with some solution. This is not something you should attempt your self because it would void any warrenity remaining on your phone. If you have a warrenity and you phone is not visibly wet and all your indicator on your phone are still negative for water damage (stickers located on or around your battery to show that your phone has water or moisture damage) then just take it in for a replacement but, leave out the part about moisture just tell them the touch screen is not responding
Nov 30, 2009 | Samsung Behold Cell Phone
Samsung jet is dead after being in the sea. Fix?
there is 1 way... but your too late
open it up and soak in dry rice and salt
it will work///
Oct 29, 2009 | Samsung Jet S8000 Cell Phone
Nokia 6233 into water
open the phone remove the batery, open the front cover get a little tiny bruss and spirit, deep the brush in the spirit and drush the phone panel then leave it dry after like 2hrs recople it back and charge the phone, it may work if the panel is not dead
Jul 02, 2009 | Nokia 6233 Cellular Phone
Phone wet(left outside in rain) kc910 now not coming on
the best bet to try would be to open up the phones casing and to use a hair dryer to dry out circuit ok
Jun 28, 2009 | LG KC910 Renoir Cell Phone
Nokia 6085 does not recognize sim card
your card is trashed. the wwtnees corruped all your files. it you put it in a computer and it never registers than its offically dead
May 17, 2009 | Nokia 6085 Cellular Phone
My phone is damp on the inside
Remove the battery and leave the phone under a vent overnight, or try using a hairdryer. Either should remove the excess moisture.
Apr 04, 2009 | Motorola Mobility E815
Wet phone - can turn on - other keys dont work
only god can answer that question...try using a blow dryer on low and if it doesn't come back to life...replace it...phone companies always have sales on cell phones.
Mar 27, 2009 | Motorola Mobility RAZR V3
Samsung Jet S8000  Cell Phone Logo
1,079 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
