Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher does not fill with water. Moter or pump is running but machine will not fill with water.
    President:
  • 949 Answers
The first thing to check is the float. Remove the lower rack, in the front right corner there is a plastic float that looks like a hat. Check to make sure something like a spoon is not stuck under it. The float should move up and down about 1/2" freely. If it is stuck up the dishwasher will not fill.
The second cause could be the house supply got shut off under the sink, this would only happen if you had someone working under there.
The last thing would be the water valve on the machine. If you take the two screws out of the lower kick panel it is located near the front left corner. It has 2 wires and 2 hoses going to it. If you have a meter you can check the coil for resistance or power to the valve when trying to fill.
Let me know if you have more questions.
Posted on Apr 30, 2010
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
GE dishwasher (GSD4020Y73BB)is running the wash cycle w/no water
the load limit switch under the tub!! is bad that controls the fill level! and if its stuck closed the machine will do that its under the machine on the bottom of the tub
Jan 13, 2010 | Dishwashers
Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Sep 17, 2009 | Frigidaire PLD4375RFC Dishwasher
My dishwasher will not fill with water therefore i can't use it. the moter is running but no water intake
Check the power coming to the water valve during the fill cycle. If power is there the valve is shot or the screen is plugged. remove the valve and check the screen or replace if clear.
Eric
Jun 28, 2009 | Whirlpool Dishwashers
Water is not filling into dishwasher. Everything sounds like it is running ok and water supply is on.
Go to the back of the machine, where the main water inlet connects. The connection there is the inlet valve that should open when you switch the machine on. Usually you have to remove the machine outer casing to get to the valve. The valves are quite cheap. Cheers, Derek.
May 19, 2009 | Dishwashers
Miele dishwasher g664 12 years old maybe?
Hi Lawrenceo,
I'm Harvey the Master Plumber.
You stated your problem as: the dishwasher won't drain.....can here a valve opening and gurgling but then no water exiting. Have cleaned everything and pushed water via tap back through water-exit hose.I to have a Miele G664 dishwasher and when turned on no water no fill. Just sits there with a moter running. Un able to get anyone to come and have a look at it as I live in Mount Victoria NSW.
It sounds like the pump has failed. The motor and the pump are two different parts. This is a common problem with older units. Frankly, after 12 years of use, at least you got your money's worth. At this age, to repair it is to throw good money after bad. It's time o replace it. You'll find there are much nicer models available now.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwasher does not spray water
It sounds like your dishwasher is doing everything normal EXCEPT washing. The unit fills properly, the timer advances properly, the unit drains and goes through a rinse cycle, plus the water is heating. I would check your main wash pump for obstructions that may be clogging it, or if it is not running at all, you need to check the interconnecting wiring and/or something in the wash pump circuit that would prevent it from running. There should be a wiring diagram/tech sheet located behind the lower kick panel under the door. I hope this helps some. Good luck and let me know what you find.
Jul 07, 2007 | Ariston Technologies LI640S Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
326 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
