Question about Bosch SHU9915UC Dishwasher
I need installation specs for a Bosch SHU9915UC
I need specs for a Bosch SHU9915UC Specs
3 Suggested Answers
bbtoast
  • 319 Answers
SOURCE: Bosch SHU9915uc/u12 making noise
TJ
I have a possible answer to your diagnostic test, see below, if this doesn't help, let me know, and I will provide more help!
Brian
SHU 991x/992x (Integra) MODELS
To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, SCRUB WASH, REGULAR WASH and RINSE & HOLD), press and hold each program button. When SCRUB WASH program button is pressed, CLEAN light also comes on andan audible tone (?beep?) also occurs.
To start testing, press both POWER SCRUB PLUS and REGULAR WASH buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
SCRUB WASH = Water filling fault (over or under filling)
REGULAR WASH = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), SCRUB WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), REGULAR WASH light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Posted on Jan 19, 2008
  • 123 Answers
SOURCE: I need the manual for Bosch dishwsher shu9915uc
http://userguides.50webs.com/
They have the largest manual database, I have
come across and the carry every Bosch product manual.
Posted on Nov 16, 2009
Bosch Dishwasher Model shu9915uc
ok sir! maybe you have defective motor thats why your unit is in abnormal power.
Oct 23, 2007 | Bosch SHU9915UC Dishwasher
Where can i download a GWH 715 ES manual?
Are you looking for sell sheet pdf, or install-care manual, or service manual.
Search: GWH 715 ES manual .pdf
Adding .pdf to search parameter helps locate manuals.
Sell sheet with venting overview, technical and product specs:
http://www.globaltowne.com/manuals/sell_sheets/715-800SellSheetFINAL.pdf
Manual for ES high altitude, with installation, error codes and troubleshoot:
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
I cannot find a service manual, or service bulletins:
http://www.bosch-climate.us/support-center/downloads/bosch-manuals/earlier-models.html
Aug 11, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
My SHU9915UC was probably installed by the previous owner in 2002. It is not working properly, may be the impeller or pump is jammed. Is it worth spending a few hundred dollars to fix it or spend another...
This model new was around $1000 dollars. I would put a few bucks into to get it back up and running. The most common issue is the circulation pump. The pump freezes up and will often cause this issue.
Appliance & Refrigerator Repair
Mar 22, 2011 | Bosch SHU9915UC Dishwasher
My Bosch Model SHU9915UC is not filling up with water. This is not a brand new unit about years old been idle for the last two years.
When any electronic mechanical device is left for any period of time, and has NOT been periodically Powered Up. It WILL need a complete overhaul,apart from electronic components going out of spec, especially capacitors, also the Valves and things get jammed up. and seize. 2 years is too long of a time to expect it to just "work" again. It will need to be attended to by a professional.I know this is most likely NOT what you want to hear, but it is true and will have to be done.
Apr 01, 2010 | Bosch SHU9915UC Dishwasher
Bosch shu9915uc dispenser assembly will not close.
there is a kit but it is easier to replace the complete dispenser. the price can be found at thermador.com
just give the model# and they will ship direct. let me know if this info was helpful with a 4 thumbs up rate.
Feb 27, 2010 | Bosch SHU9915UC Dishwasher
Nov 15, 2009 | Bosch SHU9915UC Dishwasher
What are the specs of a power adapter for an old Telex FMR-2 wireless reciever.
Check this out-including specs receiver. hope this will help ........................................
http://pdf.textfiles.com/manuals/STARINMANUALS/Bosch%20-%20EV/FMR-450.pdf
Aug 08, 2009 | Telex FMR-500 Microphone
Specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Mar 03, 2009 | Bosch SHU9915UC Dishwasher
Bosch SHU9915UC Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
