Question about GE 35GT695 TV
GE television Model #35GT695
This is the info you wanted for my problem with the sound always running back up to high every time we adjust it.
  • 1 more comment
  • Pono Mar 25, 2008
    Model # 35GT695
  • blue2182 Jul 27, 2008
    ge35gt695. tv was turning on and off. Also when it did run, the tv cycled through the channels as if it were auto programming. Unplugging the tv seemed to cure this problem temporarily. The tv now turns on but the volume runs to high and cant be adjusted down.
  • cdraper Jan 26, 2009
    In trying to program the available channels the GE tv continues to run through all channels and I Cant get it to quit.  I need a manual or info to program the tv to make it usable.
  • 3,037 Answers
Glad you fixed your problem, please don't forget to rate my solution in your previous question
Have a Good Day
Posted on Mar 26, 2008
AUX channel, cant find
If you mean the video input its either with a button or on the remote, or a few of the older GE sets it is located on a channel between 90 and 99.
Dec 22, 2012 | GE 35GT695 TV
GE TV Model 35GT695 - Problem Turning TV ON
Sounds like a solder problem. Look over the circuit board real good ffor cracked solder joints especially near the flyback and your Horizontal output and regulator transisitors. Could also be a defective capacitor look for signs of bulging or leaking capacitors.
Jan 15, 2008 | Televison & Video
NO SOUND ON GE 46GW947 TV
Look first to see if the set has the GUIDE PLUS LOGO ON THE FRONT OF THE CABINET OR in the menu, if so unplug set and plug it back to get sound back.
Things to check that are easy, look first:
Does set have sound with a DVD etc connected to a rear input?
Does set have a setting for turning the speakers off or to external speaker hookup?
last might be a actual audio circuit problem but I have never seen that in this model.
Dec 18, 2012 | GE 35GT695 TV
NO SOUND ON GE 46GW947YX1 TV
Check its speaker first. If is found OK, check and replace damaged component, in the audio output section.
My GE 35GT695 has lost color and will only show in black & white. However, when I press the menu button the menu shows in color while the screen is still black & white.
the on screen graphics are sourced from red,green ,blue drives,..your fault is with the colour decoder .sorry it is a repair that needs a expert engineer ..it could be dry jointed to test for dry joints try tapping the back cover or bottom of the set ..good luck farr64[colin]
Dec 29, 2009 | GE 35GT695 TV
Model 35 gt695 no pic or sound .went to move tv to clean and seen a flash on top right of screen.worked fine after that .in the morning came on fine for 10 minutes then heard a pop and it went off.light...
Most likely the high voltage transformer took a dive. If the picture was still good before it went out it is probably worth a check out fee. Another possibility is that there was a loose solder joint developing and moving the set around helped the loose joint come completely undone. Thanks
Oct 17, 2009 | GE 35GT695 TV
DTV in Feb. 2009
I called the manufacturer and they gave me the info I needed.
Aug 23, 2008 | GE 35GT695 TV
Keeps Blowing The 5 Amp Fuses
There is a short in either or both the main power supply or one of the scan amplifier sections and or the high voltage section.
You will not bel able to service this yourself. This type of repair can be fairly involved and complicated to troubleshoot.
An expericed TV tech should be able to service this for you.
Jerry G.
Jul 07, 2008 | GE 35GT695 TV
TV Repair
was the set good to you in them 10 years if yes put it to rest,the cost exceeds replacement value and the weight alone will take a toll on your body. let it go/
Aug 30, 2007 | GE 35GT695 TV
Televison & Video Logo
132 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
