Question about Lite On SHW-160P6S (SHM160P6S04) DVD RW Dual Layer Burner
Won't read any disc
When I put a blank CDR for making a music cd, the drive tries to spin up then stops. After a few minutes, the LED blinks three times and then three times more. The system never sees that a disc has been inserted...dirty lens or bad spin motor? Thanks!
  • ned4879 Mar 28, 2008
    i have the same problem,when i insert a blank cd-r it says please insert a writtable disc.it makes some constant cracking noises for and then tries to read it and thats it,it just stops.when i put audio cd which i have burned before it plays them.
  • 97 Answers
Could be dirty lens. I'd almost bet bad run of CD-r's though. Does the drive recognize finished cd's? If so it the CDr's.
Posted on Mar 25, 2008
I don't founr cd 74 mn 650mb, what use the DENON CDR M30 ??
If I understand your question, it can play any kind of music CD but it can only record on CDR-Audio or CDR-Music discs only.
• Only audio CD-R/RW discs can be recorded with this unit. "Use Audio CD" will be displayed when a disc other than one
for use with audio such as a CD-R/RW disc for use with a personal computer or another type of disc is loaded. (See "Discs that Can Be Used with this Unit" on Page 5.)
• CD-R discs can be recorded to only once. The recorded information cannot be erased.
• The recorded information of CD-RW discs can be erased. When this disc has been finalized, erase after the finalization removal operation has been performed. (See "Cancellation of CD-RW disc finalizing" on Page 28.)
• Recording mistakes made with CD-R discs cannot be erased; therefore, it is recommended that a CD-RW disc be used until you are accustomed to the recording operation.
If you desire 74-minute blank disc just Google "cd-r audio 74". The unit will also use 800MB 80-minute CD's.
Jan 31, 2011 | Denon CDR-M30 CD Recorder
Cdr is not reading blank disc shows disc error
A few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Sometimes spindle dvd blanks have a few bad ones.
Check manual, might describe exactly what types of dvd blanks are best to use with the unit.
Just some suggestions, hope this helps.
Apr 27, 2010 | Denon CDR-W1500 2-Disc CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
Sep 09, 2009 | Computers & Internet
My cd is well ....i have no idea
Sounds like a tough problem to have because half of the CD drive is working fine (the reading part) but half isn't (the writing/burning part).
Here are a few suggestions:
1) try a different CD writing program, if the Wizard says the CD-Rs are full, try a version of Nero or a freeware burning program.
2) if, when you load the blank CD, Windows says that it's unable to burn it, it might not be a CD that your burner can recognize. If you are using different or new CDs, try another one or borrow someone else's blank CD. I've had it happen where a set of CDs that I bought were bad and couldn't be used. Also, some cheap CDs don't work on some CD burners.
3) It might be a bad CD drive. If it's an older computer, you might have to get a new CD drive. Before doing this, I'd try reinstalling the software and drivers for your CD burner and try both the suggestions from above. Good luck
Sep 09, 2008 | Compaq Computers & Internet
Cdr s1000 help
Hi Rick
The unit has stopped reading discs. I suggest taking the lid off and cleaning the laser lens with a cotton bud with a little Windex , then give it a gentle polish to be sure no residue smearing is left. If that does not fix it, check to see what actually happens when you load a disc. Does the transport fully engage and clamp the disc correct into the chucking assembly. Let me know how you got on:)
regards
Graeme
Apr 06, 2008 | Yamaha CDR-S1000 CD Player
Problem with Sony RCD-W1 CD recorder
'No audio' comes up when you use the wrong type of cdr in the drive. You need a 'consumer audio' or 'music' specific CDR and not a generic computer cdr to use in these units.
Sep 27, 2007 | Marantz CDR631 CD Recorder
Lite On SHW-160P6S (SHM160P6S04) DVD RW Dual Layer Burner Logo
226 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
