Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
I replaced the lamp how do i reset the counter panasonic pt50dl54
I tried the hold down volume on the TV and mute on remote method but I do not see any message on the screen, does that mean i did not reset it or is it normal to not have confirmation that it is reset.
You will see the green light (power) flashing
Posted on Jul 31, 2010
  • grduquette Nov 24, 2010
    J'ai utilisé Vol- sur Tv et ``Mute`` sur le remote
  • 50 Answers
There is no confirmation.
Posted on Jun 25, 2010
How do i reset the hour meter on my panisonic
RESETTING LAMP HOURS
Consult Your owners Manual but this works for most Panasonics
Turn on Power
Press and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 23, 2009 | Panasonic Televison & Video
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Mar 16, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Reset lamp life counter pt-50dl54j
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Feb 19, 2009 | Panasonic Televison & Video
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
It is the MUTE button on the remote and the VOLUME DOWN on the TV.
May 11, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Resetting bulb tyla1000
Most modes can be reset by holding the volume down button on the tv until the volume is all the way down. Continue to hold the volume down button on the tv and while depressing the volume down button on the tv press and hold the pip button on the remote until the reset message appears on the screen. Some models are different and while depressing the volume down button on tv press and hold the split key on the remote. Most times these instruction come inside the lamp box you purchased.
Mar 28, 2008 | Televison & Video
Projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
745 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
