Question about Kitchen Ranges
Stove no sparks - Kitchen Ranges
    Guru:
  • 93 Answers
The spark modulator is the component that "Sparks" If you have no sparks, then you probably have an issue with you spark modulator.
Posted on Mar 25, 2008
SOURCE:
Where is the pilot light on a GE profile gas stove? The burners suddenly would not light except with igniter.
Please add the make and model number of the stove. Modern gas stoves and ranges do not have a pilot light. They light the gas with an electric spark. On these models, there is a knob setting for "Light" which triggers the spark. If there is no A/C voltage to the stove, you can use a match or butane lighter to light the stove with care.
I've found that the ignition system can fail if the burner caps are not seated properly. Debris in the burner area can also lead to the ignition spark problems. If you take off the burner cap and head (for some models), the electrode will be visible. Clean off any carbon build up on the electrodes for better sparks.
Jan 22, 2017 | GE Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Defy 731 multifunction oven stopped working
switch as probably burt out so that the connecors inside dont touch anymore, or your supply fuses for the stove have blown, check your fuse box. but at any rate if there are sparks i would replace stove or get in a qualifed person the check your stove.
Oct 22, 2014 | Ovens
My stove made this zapping noise, sparks came out the bottom and then tripped the breaker.
You need to have the stove looked at by a qualified appliance tech. The fact that the stove sparked and tripped the breaker indicates a short some where in the stove and it is very unsafe to use it. Leave the breaker off until you have the stove serviced.
May 23, 2014 | Whirlpool Gold GW397LXU 30" Slide-in Gas...
All the burners are turned off on my gas stove, but one keeps sparking uncontrollably...its been all night now. I have lifted burner cap off and can see the spark but have no idea how to stop it. Our...
This is dangerous.
You should be able to stop it by unplugging the stove. The automatic spark requires electricity to work.
Unplug it and leave a comment with the make and model and I will assist you in finding a replacement.
Mar 31, 2011 | Microwave Ovens
I have an Amana ARGS7650ww. The igniters will not spark.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 20, 2010 | Microwave Ovens
Clicking on stove top will not stop
Unplug the stove top for a few days, and let the burner switches dry out. Sometimes this is caused by moisture getting into the switches from a boil over, or from someone cleaning the stove top. If your unit still sparks after a few days then you will have to replace the bad burner switch, or switches. I am assuming that you are talking about a cook top that is sparking all the time, and not about a cooktop that is sparking, even after the burner lights. If your burner is still sparking after it lights, you usually have a bad spark module. Good Luck, Appliance Specialists
Jan 17, 2010 | GE Kitchen Ranges
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Old tappan in counter gas stove/range
sorry, misinformation, no such child lock existed in those days, either your spark module is bad or your switches are bad, (unusual for all switches to fail simultaneously)
Apr 02, 2008 | Tappan TGF364AS Gas Kitchen Range
Kitchen Ranges Logo
188 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
