Question about Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger
Battery discharging I just bought a 2005 vtx1300 and since then the battery will be discarged in about three days if it has not been running, its not one of the cheaper batteries it has a side post on it, the previous owner told me it is about a year old, the battery has a bout 7 wires connected to it for all the accesseries, and does the side post wire hook up have to be seperate from the other wires? I know I said a lot, but hope I can get some answers. why is the battery dying? thanks lou
  • 623 Answers
First off, disconnect all those accessory wires, leave only the battery cables hooked to the battery. Charge the battery properly over a long time with small voltage input so the battery won't overheat and warp the plates inside.
The voltage after fully charged should be about 12.75v-12.80v, when you check the battery with a voltmeter.
I am quite certain that one of the accessories is drawing down the battery which is why it is dying in three days.
You might want to buy a little hydrometer made for a MC battery too, so you can check each cell to make sure there is not a dead one, this too can cause the battery to go dead in three days, because it will not hold a charge.
Posted on Apr 30, 2010
I bought a cordless Dyson, three days ago. I have charged it three times. It states that this model has a twenty minute running time. This one runs less than 10 minutes. JU6-US-HEA1415A
If after a few more discharge, charge cycles unit still underperforms then return for exchange or money back. Newer batteries have to be "exercised" a tad before they perform up to specs. And if they say 20 minutes, then hold them to it!!!!!!!!!!!!!!
Nov 28, 2016 | Vacuums
2005 honda vtx1300 battery wont hold a charge while the engine is running
you have a bad battery. or the water levels are to low on your battery and the cells aren't being completed so it won't hold a charge then either. you can pop the top off of your battery and look and see and if they are low add some distilled water
May 29, 2015 | Honda VTX 1300 Motorcycles
What type of synthetic oil should i use on my 1300 vtx r?
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
What oil do you use for your VTX1300
Best oil
Honda VTX1300S Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2007 VTX1300S Owner Manual
Apr 16, 2014 | 2005 Honda VTX 1300 R
Remove seat on 2005 honda rune
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $12 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://itstillruns.com/remove-vtx1300-seat-7560573.html
2004 honda rune trex ride
NRX1800 Valkyrie Rune 2003 Workshop Repair Man Download Manuals Technical $12
http://mybikemanuals.com/honda
Apr 12, 2014 | 2004 Honda Valkyrie Rune
I have a 2003 ford focus wagon second hand. My battery died out and I thought the alternator was the problem. Brought my car to an alternator repair shop and they said the alternator is still good. I ended...
Lead acid batteries don't like being discharged flat, and it could now be damaged and unable to hold a charge. It does sound as though the voltage regulator part of the alternator is allowing discharge to ground when it should not. You would seem to have a good warranty claim on the battery given they did check the alternator and pronounce it OK.
Nov 04, 2013 | 2003 Ford Focus
Does any one know the timing mark setings for a vtx1300 2011
2006 vtx1300 timing marks
http://www.xs11.com/forum/showthread.php?t=39154
Honda VTX1300T 2009 Owner Manual
Sep 09, 2013 | 2011 Honda VTX1300C
How to remove fuel tank from 2005 honda 1800 vtx@
Gas Tank Removal 02 04 VTX 1800 Bareass Choppers Motorcycle Tech Pages
VTX1300 Tank Removal
http://www.k1400.cz/manual/honda/vtx_1800/Honda_VTX1800C.pdf
Honda 2005 VTX1800C Owner Manual
Apr 29, 2013 | 2005 Honda VTX 1800
8 year old side by side, refrigerator and freezer not cold, compressor running, condenser fan running, discarge line not hot suction line not cold
discharge line not hot suction line not cold. This indicates the compressor is not working properly. It could be out of freon or just not pumping.
Nov 03, 2010 | Maytag Refrigerators
2005 Honda VTX 1300 R will not idle
Hi, Shirleypaw and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
07 VTX 1300S won idle after adjusting screw to 2 1 2 turns out 2005 VTX1300 won stay running
https://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
Feb 25, 2009 | 2005 Honda VTX 1300 R
Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger Logo
42 people viewed this question
Top Heavy Duty Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Heavy Duty Electrical Supply Expert? Answer questions, earn points and help others
