Question about Garden
Instructions for Etesia PSE lawnmower
Etesia PSE lawnmower - Suzuki motor I want to know where the oil goes and whether I can download instructions on servicing the motor.
3 Suggested Answers
emissionwiz
  • 75005 Answers
SOURCE: etesia drivebelt
This is posted in the wrong product category, please post again.
Posted on May 26, 2012
SOURCE: Harry Prisma 37 Petrol or mix?
your question was put in the sewing machine catagory,
if you put it in the lawnmower catagory, then someone can help you
with a answer
Posted on Jun 02, 2012
How much oil and what kind do I use for a 1993 Suzuki GSXR 750?
As long as you aren't talking about Fork Oil, normally, the filler has a dipstick.
From here
http://www.gsxr.com/13-tech-performance-chat/25566-motor-oil-type-gsxr-750-04-a.html
so I found my manual; it specifies that an '04-'05 GSXR 750 should take SF or SE motor oil 10W-40. It does not say specifically that motorcycle oil should be used nor does it specify synthetic vs. regular. I also do not know whether SG or other grades of oil would be better. I probably ought to read an oil guide but, for the benefit of others, perhaps somebody could provide some input.
Fork Oil type and quantity is here
http://www.motohouston.com/forums/showthread.php?t=51927
fork oil weight and quantity recommendation for GSXR 750
Apr 06, 2016 | Suzuki Motorcycles
Etesia lawnmower
Check to see if choke is closing and opening properly, if yes, adjust the carburetor as it appears you are not getting enough fuel flow with the amount of air intake.
Jun 07, 2013 | Garden
Does the transmission on a pony lawnmower need oil
It will contain some form of lubricant whether it is oil or grease. It will depend on the transmission manufacturer to know which one. If it is oil it may be a special type
Jan 22, 2013 | Troy Garden
Will putting oil in the gas tank of a 2 cycle lawnmower riun the engine?
It is not good for that motor--drain and clean and expect plug may get fouled---do it the sooner the better.
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
with a answer
Jun 02, 2012 | Sewing Machines
Etesia drivebelt
May 26, 2012 | Cars & Trucks
Does anyone know whether these Yard Machines lawnmowers take straight gasoline or mix? I cant find an onwers manual online to clarify it. To be clear I seem to have a bit of an oddball machine;...
Straight gas. Look around, and you will see where to fill the engine with regular sae 30 oil, and on lawnmowers, if you have a place to fill it with oil, you don't mix oil with the gas.
May 18, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
I HAVE A 99 Suzuki Escudo 2.0d RF-Motor. How much OIL?
A typical Mazda RF Diesel Engine requires approximately 5.5litres of engine oil if the engine oil filter is replaced as well.
Mar 13, 2010 | 1999 Suzuki Vitara
Can't start it up - no instructions
Steps
  1. Make sure you have enough motor oil in your mower. Usually there is a cap on top of the mower body, smaller than the gas cap, that says "oil" or something similar. The cap will probably have an oil gauge attached, so check the oil as you would in a car, that is, judge the level of oil on the gauge against the depth of the reservoir (the length of the gauge).
  2. Make sure you have enough gasoline. There should be a clearly labeled cap on the gas tank. If you open it, you should be able to look down into the tank and see the approximate level. Add more (preferably using a funnel) if needed.
  3. Locate the prime button, usually red or black, a squishy button somewhere on the mower's body. Push it between 3 and 8 times in order to force the gasoline into the lines.
  4. You may need to pull and hold a starting lever (a safety feature), or the lawnmower will not start no matter what you do.
  5. Brace your arm holding the starting lever, and pull upward on the pull cord, which you should find on top of the mower body. You may have to do this several times before the motor starts up.
  6. If you are still unable to get your mower started, try the lawnmower inspection and troubleshooting steps at http://www.wikihow.com/Repair-a-Lawnmower.
http://www.wikihow.com/Start-a-Push-Lawn-Mower
May 11, 2009 | Garden
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
