Question about Gateway (G-MAX2000) Computer Speakers
I need to take apart a gateway speaker
One of my kids stuffed some items in the hole in the back of the speaker and I need to get these items back. Is there an easy way (with out tearing up the speaker) to take it apart?
Need to fix LG ULTRAHD TV 43UJ6300 screen cracked
Kids eh... who needs em..nothing but trouble. Anyway it's stuffed. It'll cost more to try and fix than to git a new one so sell the kid git a new telly and no more problems.
Nov 05, 2017 | LG Televison & Video
Tip
Damping
for improved performance out of these radios try stuffing some speaker insulation in both of the speaker cavities in the front . make sure you dont over do it so that the speakers install without the insulation hindering them resting flush on the mounting surface when you reinstall them.There is room around the sides inside the cavity for sufficient material.Use as much as you can without hindering reinstallation. I also took mine completely apart and added insulation to the subwoofer cavity,along the top which has divisions good for pieces of insulating material and near the woofer also a few more pieces where there was room for it.BIG difference .Most speaker cabinets have insulation to help control standing waves and cavity resonance and plastic cabinets will also benefit.When you put the screws for the front speakers back in make sure they are just snug without overdoing it.When you install the top to the bottom [only if you decide to do the main part with the subwoofer] make sure they are tightened all the way otherwise the top and the bottom will add resonance from not being securely anchored to each other ONLY TIGHTEN SCREWS WITH A HAND TOOL SO YOU DONT STRIP THE HOLES OUT !
on Oct 04, 2013 | Cambridge Soundworks SoundWorks 730 Clock...
Tip
HOW TO STUFF A KONG DOG TOY AND WHAT TO STUFF IT WITH
Kong toys are one of the top selling brands of dog toys. They are durable and safe. I have 4 dogs and they all love playing with their stuffed Kong toys.
How to stuff a Kong toy:
  • Try squeezing the toy from the side so that the opening becomes oval-shaped, thus making it easier to get the stuffing inside
  • If the filling is more of a liquid, try mixing the ingredients in a Ziploc bag and trimming the corner allowing you to "pipe" the filling into the toys' opening.
  • To keep liquid stuffing from running out, try blocking the bottom of the hole with a solid piece of food. This will also help keep your dog occupied for a longer period of time.
  • Try lining the sides of the toy with something like honey or peanut butter and place it in the freezer.
I will attach a link here of a great instructional video that will further help you in learning how to stuff your Kong toy.
http://www.youtube.com/watch?v=bz-IZbfzKvU
In regards to the types of stuffing, there are endless amounts of items you can choose from. One of the more popular items is peanut butter; however I try not to use it too often as it can be quite fatty for dogs.
Here is a list of some other items I like to use:
Honey
Mashed bananas
Dog biscuits
Cream cheese/cottage cheese
The following site will provide you with several recipes that your dog will love as well as a few more stuffing tips.
http://westwoodanimalhospital.com/BhvArticles/kong_stuffing.htm
on Aug 28, 2012 | Dogs
How to clean a poulan 250 A chain saw carburator
VERY CAREFULLY! If you break or split any gaskets getting it apart, you're stuffed. If you lose the needle spring, you're stuffed. Once fully dis-assembled all ports can be accessed with a fine wire, however don't poke it through the holes in round discs in the bottom- these are one-way valves. Usually there will be gelled oil in the fuel inlet elbow. Fine wire should get around there, then blow out with air compressor. Be sure to check the bottom diaphragm for pin-holes, and blow out the LO/HI jet holes.
Oct 11, 2016 | Poulan Garden
How do you take apart the gateway mouse so that I can clean the inside parts I think they got too dusty inside?
I wouldn't recommend taking apart the mouse unless you have at least one spare. Some of the parts inside can be a delicate and difficult to put back into place, if your unused to them.
If you still want to take apart your mouse, first unplug it from the computer, then turn it over so your looking at the bottom. There should be two "feet" on the bottom of the mouse, though sometimes more. These will commonly look like little plastic nubs or smooth "sliders". Use something with a thin edge and gently pull them up and away, and you should find screw holes underneath. Use a small screwdriver, commonly a Philips, to take out these screws. Your mouse should now easily pull into two pieces. Go slowly as you take the mouse apart, in case anything falls out or comes lose, so you can see where it was and how it fit into place.
To put your mouse back together after cleaning it, simply place the two halves back together once all the internal pieces are in their correct place, and tighten the screws again. Pop the "sliders" over the holes and it'll look like new.
Mar 06, 2011 | Gateway Computers & Internet
2004 nissan sentra all buttons work on radio but there is no sound
open trunk and look very carefully at the copper colored wires on bottom of rear speakers and make sure they are not contacting speaker frames and shorting out.often occurs whe stuffing large items in trunk.this will shut down all four channels so radio is not damaged.hope this helped.
Dec 27, 2010 | 2004 Nissan Sentra
How do i connect some gateway 2000 speakers to my desktop compaq computer
hi
back of your desktop there is the sound card and you will find three holes for the speakers you will choose the green.
Aug 02, 2010 | Compaq PS110 Computer Speakers
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
How do i disasemble the speaker to get toys out!
Try removing the speakers, you should have a few screws to remove and should be able to get the toys
Feb 01, 2010 | Audio Players & Recorders
My kid forgot BIOS password.
You'll need to contact Gateway Tech support for a master password most likely
Jan 26, 2009 | Gateway MX3228 Notebook
Gateway (G-MAX2000) Computer Speakers Logo
51 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
