Question about Canon PIXMA iP5000 InkJet Photo Printer
Color printing My printer will not print color after I went through "Absorber almost full" problem. I used reset instructions and it printed great several times. Now when I try a nozzle check page it page it does not print in color. I reinstalled the printer but it still won't print.
  • Anonymous Mar 23, 2014
    My printer is printing on half of the page, down the left side. It's cutting everything off on the right side. I've tried everything to get get it to print the full page. Any suggestions??
I removed the ink tanks then I removed the print head very carefully.
I rinsed the print head with the cleaner that comes with my refill
bottles, let it dry and carefully reinserted the print head. I "cleaned"
the nozzles and ran nozzle check and it worked fine.
I no longer trust this iP5000 printer for photos so I have purchased a new
Canon iP6700D which is great. I will use both printers...only using
the new one for photos only.
The main thing I have learned from my Canon printers is not to clean
the print heads as often due to that "Absorber almost full" message!
I still like the Canon for the ink capacity and separate tanks.
Your site has been so helpful! Thank you!
Posted on Mar 27, 2008
THE INK ABSORBER IS FULL. HOW CAN I RESET MY PRINTER?
To Cleared ink absorber full error you can do it by accessing into maintenance mode. Using number code.
May 09, 2015 | Brother MFC-J5910DW Color Inkjet...
I am getting an 5800 error
Ink Absorber Replacement OptionsThis printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk
the 5800 code. uplug cord from outlet. wait 1 full min, then plug in and let go through self test.
reply for more help.
have a great day and please rate bama46, thank you
Aug 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Used ink ?
From CANON FAQs:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i350
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Solution: Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Aug 13, 2009 | Canon i350 InkJet Printer
Waste Ink Absorber is almost full.
Press and hold the resume button until the power light flashes twice, a nozzle check print will print. If all the colors aren't there you will need a printhead, a repair shop would need to replace the ink absorbers and reset the counters.
Jun 22, 2009 | Canon S520 InkJet Photo Printer
My canon i950 waste ink absorber is almost full
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Mar 17, 2009 | Canon i950 InkJet Photo Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Waste ink absorber full
Hi ....
Do vote if this helps ... Cheers :)
Dec 20, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Waste tank absorber is almost full ~ message
I've taken this from my manual.
This error message indicates that the ink absorber is nearly full.
The machine has a built-in ink absorber to hold the ink used
during FINE Cartridge cleaning, for example.
You can continue printing by selecting Continue*1
on the display on your camera.
However, because printing is disabled once
the ink absorber becomes completely full
and until the ink absorber is replaced, you
are recommended to contact a Canon
service representative as early as possible.
*1 To resume printing, you can press
[OK] (MP180) / [Black] or [Color] (MP160) on
the machine instead of selecting [Continue].
Feb 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Ink tank absorber full
Hi ....
Jan 26, 2008 | Canon I990 InkJet Photo Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
320 people viewed this question
old marine
old marine
