Question about Facebook Social Network
Internet explorer script errors in facebook - Facebook Social Network
  • stgbruced May 04, 2010
    I still get the script error messages. Please note I only get the script errors in facebook.
    President:
  • 524 Answers
  1. Start Internet Explorer.
    Select 'Tools' from the toolbar menu.
    Choose 'Internet Options.'
    Click on the 'Advanced' tab.
    Scroll through the list of options until you see the heading labeled 'Browsing.'
    Put checks in the boxes labeled 'Disable Script Debugging (Internet Explorer' and 'Disable Script Debugging (Other).' When you have done this, click 'OK.' You should no longer see script error messages when you cruise the Internet.
Posted on May 01, 2010
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 04, 2010
    Method 1: Disable script debugging
    loadTOCNode(3, 'whattotry');
    If the only sign of a problem is the error message, and
    Web sites are working, you can probably ignore the error. Also, if the
    problem only happens on one or two Web pages, it might be a problem with
    those pages. If you decide to ignore the errors, you can disable script
    debugging.
    Note If this problem occurs on more than one
    or two sites, do not disable script debugging. Go to method 2 now.
    To turn off the Scripting Debugger in Internet Explorer 6,
    follow these steps:
    1. On the Tools
      menu, click Internet Options.
    2. On the Advanced tab, click to
      select the Disable script debugging
      check box. and then click OK .
    To turn off notification about every script error in Internet
    Explorer 7, follow these steps:
    1. On the Tools
      clear the Display a notification about every
      script error check box, and then click OK.
    Method 2: Test a Web page from another
    user account, another browser, and another computer
    Use another user account, another browser, or another
    computer to view the Web pages that triggered a script error to
    determine whether the problem persists. If the script error persists,
    there may be a problem with the way the Web page is written. You can
    probably ignore the error and disable script debugging as described in
    method 1.
    If the script error does not occur when you view the
    Web page from another user account, browser, or computer, the problem
    may be caused by files or by settings on your computer. Go to method 3
    to continue to troubleshoot.
    Method 3: Verify that Active Scripting, ActiveX, and
    Java are not being blocked by Internet Explorer
    Active scripting, ActiveX, and Java are all involved in
    shaping the way information displays on a Web page. If these are
    blocked on your computer, it may disrupt the display of the Web page.
    Reset the Internet Explorer security settings to make sure these are not
    blocked. To do this, follow these steps:
    1. Start Internet
      Explorer.
    2. On the Tools menu,
    3. In the Internet Options dialog box, click the Security tab.
    4. Click Default Level.
    5. Click OK.
    Note ActiveX controls and
    Java programs are turned off at the High security level in Internet
    Explorer.
    Try to open a Web page where you previously received a
    scripting error. If you do not receive the error, the issue is resolved.
    If the issue persists, go to Method 4.
    Method 4:
    Remove all the temporary Internet-related files
    Every time that you open a browser to view a Web page,
    your computer stores a local copy of that Web page in a temporary file.
    If the size of the temporary Internet files folder becomes too large,
    some display problems may occur when you open Web pages. Periodically
    clearing the folder might help resolve the issue.
    To remove all
    the temporary Internet-related files from your computer when you use
    Internet Explorer 6, follow these steps:
    1. Start Internet
      Explorer.
    3. Click
      the General tab.
    4. Under Temporary Internet files, click Settings.
    5. Click Delete
      Files, and then click OK.
    6. Click
      Delete Cookies, and then click OK.
    7. Under History,
      click Clear History, and then click Yes.
    8. Click OK.
    To
    remove all the temporary Internet-related files from your computer when
    you use Internet Explorer 7, follow these steps:
    1. Start Internet
      Explorer.
    3. Click
      the General tab.
    4. Under Browsing History, click Delete,
      and when you are prompted, click Yes to
      confirm.
    5. In the Delete Browsing History
      dialog box, under Temporary Internet Files,
      click Delete Files, and when you are
      prompted, click Yes to confirm.
    6. Under
      Cookies, click Delete
      Cookies, and when you are prompted, click Yes to confirm.
    7. Under History, click Delete
      History, and when you are prompted, click Yes to confirm.
    8. Click Close, and then click OK
      to close the Internet Options dialog
      box.
    If the issue persists, go to method 5.
    Method 5:
    Install the latest service pack and software updates for Internet
    Explorer 6 or Internet Explorer 7
    If you do not have the latest service pack or software
    upgrades for Internet Explorer 6 or 7, download and install them. They
    may contain updates that can help resolve the issue.
    To install
    Internet Explorer 6 Service Pack 1, visit the following Microsoft Web
    site:
    http://www.microsoft.com/downloads/detai...
    (http://www.microsoft.com/downloads/detai...)
    Note
    Internet Explorer 6 Service Pack 1 is recommended for systems that are
    running versions of Windows earlier than Windows XP.
    To install
    the most current software updates for Internet Explorer 6 or for
    Internet Explorer 7, visit the following Microsoft Web site:
    http://windowsupdate.microsoft.com
    (http://windowsupdate.microsoft.com)
2 Suggested Answers
  • 85 Answers
SOURCE: Facebook won't open. Internet Explorer error pops up &
This is a problem with the computer, more specifically with the browser you are using.
It seems that some addon required for facebook in not correctly working.
You can reset the browser (note: it deletes passwords and history of websites you have visited but favorites will remain there).
Procedure for this is below:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Internet Options.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
If that does not fix it, run antivirus scan. Let me know for further clarification or further assistance. I will be glad to help.
Posted on Jul 30, 2009
Long running script zedo.com
I understand that you are getting the script error. Refer the link for the information to troubleshoot script errors in Internet Explorer:
http://support.microsoft.com/kb/308260
The information contained in the link Applies to
  • Windows Internet Explorer 9
  • Windows Internet Explorer 8
  • Windows Internet Explorer 7
  • Microsoft Internet Explorer 6.0
You may also try reset the Browser and check the operation.
Nov 18, 2013 | Dell Dimension Computers & Internet
Keep getting a box popping up talking about script errors. how do we stop that?
If you use Internet Explorer as your Web browser, chances are you have experienced, or will experience, popup script errors. Typically, a dialog box may appear stating "A Runtime Error has occurred. Do you wish to Debug?" or "Internet Explorer Script Error. An error has occurred in the script on line 1. Do you wish to continue running scripts on this page?" These errors can be distracting and interfere with your Web browsing experience. If you would like to stop receiving these error messages, you must modify your IE settings.
Open IE, select "Tools" and ten choose "Internet Options." The Internet Options dialog box will open. Click on the "Advanced" tab, scroll to the "Browsing" section and then select the "Disable Script Debugging" box.
Clear the "Display a notification about every script error" box under the same section if it has been selected. Click "Apply" and then choose "OK" to modify your IE settings. You will receive no more IE script error notifications. Hope this helps.
Jan 01, 2013 | Microsoft Internet Explorer 8
Script problem in Explorer 8
What should you do about Internet Explorer script errors?
In most cases, you can ignore them. Script error messages are displayed by Internet Explorer when there is a problem with the JavaScript or VBScript code on the website you are viewing. Occasionally a script error can be caused by an error in downloading a webpage, but more often it is an error in the webpage itself.
To be sure it isn't an error in downloading, click the Refresh button, or press F5.
getcontent.aspx?assetid=6d65df30-1154-45a1-9855-1232c6b27475&documentset=en-us&prod=win700&market=usInternet Explorer refresh button
If the error persists, and you are not a developer testing a website, you should click No to ignore the error.
To avoid script errors in the future, you can turn off script debugging and notifications in Internet Explorer. Script error debugging and notifications are turned off by default. If they have been turned on, follow these steps to turn them off again.
  1. Click the Tools button, and then click Internet Options.
2. Click the Advanced tab, select the Disable script debugging (Internet Explorer) and Disable script debugging (Other) check boxes.
3. Clear the Display a notification about every script error check box, and then click OK.
Apr 25, 2011 | Microsoft Internet Explorer 8
Face Book is not opening fully in both chrome and explorer. below is the error message shown in explorer. pls help. Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT...
You may try this first on IE.
a. Click theTools button, and then click Internet Options.
b. In theInternet Options dialog box, click the Advanced tab.
c. Click to select theDisable script debugging (Internet Explorer) and Disable script debugging (Other) check boxes, and then click to clear theDisplay a notification about every script error check box.
d. ClickOK to close the Internet Options dialog box.
You may also flush the dns and reset winsock.
Go to run and type in cmd.
On the dialog box type in "ipconfig/flushdns"(without the quotation) and enter.
Type in as well "netsh winsock reset"(without the quotation) and enter.
Restart the computer.
Apr 11, 2011 | Facebook Computers & Internet
I am ask to stop the script everytime i open my facebook
It's a problem with your browser, you can add facebook to allow scripts and control applets defined within your browser's internet options.
Mar 01, 2011 | Computers & Internet
Script error loading farmville on facebook. slows down internet explorer and creates a not responding situation. driving me crazy.
Use alternative browser. Mozilla Firefox runs Facebook better and loads faster than any other web browser like Internet Explorer.
Here download this file to help you with farmville and any zinga games
1. Mozilla Firefox 3.6
Jul 07, 2010 | Facebook Social Network
Running script error
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  2. On the Tools menu, click Internet Options.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  3. Click the General tab.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
Jul 06, 2010 | Computers & Internet
Internet Explorer Script Issue ? When I mov from Homepage to profile n IE Script error dialogue box opens
If you want to disable Internet Explorer's displaying windows when there is a script error on a page,
  2. Go to Tools / Internet Options
  3. Click on the Advanced tab
  4. Under the Browsing section, check Disable script debugging and uncheck Display notification about every script error
    Source: http://www.onecomputerguy.com/ie_tips.htm#script_debug
Dec 19, 2009 | Computers & Internet
Every time i try to log into facebook, at the bottom of the screen it will say: errors on page
Don't worry about it. It either means that your version of Internet Explorer cannot understand the script or there is a programming error. If you're using anything lower than IE7 upgrade.
Jun 30, 2009 | Facebook Social Network
Facebook Social Network Logo
748 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
