Computer restart Miss Llita, I have computer when I try to install windows xp,It setups and installing devices part it will automatically restart.After that I was remove the processor ,RAM and reinstall it.Then try to install xp that time it was installed.then after loading windows again restart.Then I remove the power supply and restart again after that it works and load windows xp.Then I closed power supply and power on the computer it works without problem.I was used it one hour time it was again restar.I was check the processor.It was too hot.Computer is a pentium 4 with Intel pentium 2.4GHz Processor.Processor also have a small heat sink and 12V DC Fan.I think problem with it.When over heats the processor it will auto restart.I try to install additional Fan to CPU unit to solve this.Please give me ur suggestions to me. Reply me soon. Janaka Wickramaratna Technical officer Department of Electrical Engineering University of Moratuwa Srilanka
  • 385 Answers
Have you tried replacing the entire heat sink with a bigger fan. They sell heat sink plus fan but you have to buy one that fits unto the motherboard.
Also, if this processor keeps heating up, the processor itself might get damaged, if it hadn't already. You might want to get the processor itself tested at a computer repair shop or if you have another computer using same type of processor.
Thanks,
Lolita
Posted on Apr 07, 2008
    Champion:
  • 209 Answers
Yes the problem as you discussed was the processor's overheating. first, you need to open up the side cover of your casing then switch on check vissually if the fan of the processor is spinning if not then you need to replace this. and if this is spinning upon power on, the power supply will be checked its voltage.
Posted on Mar 29, 2008
6ya staff
SOURCE:
How to setup a new xp windows
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
if your installation disk is only a service pack 1 or 2 you might need to create an xp sp3 disk
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
hope this helps
Oct 12, 2012 | Fujitsu Computers & Internet
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
Tip
Installing Windows XP
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Every one who owns a computer should maintain it on their own from time to time.
Reinstalling your Operating System is one of the methods of computer maintenance, and is a bit complex.
With these steps, you will successfully install Windows XP into your computer.
These steps are similar to other Windows OS installations (Vista, Windows 7).
Below is the detailed procedure of installing Microsoft Windows XP:
  • Before installing Windows XP or any other operating system, you should backup all your data. Data can be backed up on a separate partition, if the hard disk is partitioned or you can back it up on external storage devices like CDs or on a network.
  • Restart the computer and go to the Setup menu by pressing F2 and change the first boot device to CD, press Esc and save settings.
  • Insert the CD labeled Microsoft Windows XP into the computer and restart the computer.
  • When the pc restarts, a message will appear telling you to press any key to boot from CD, press a key immediately the message appears and the setup process will begin.
  • After the files have been loaded, Windows will start and it will give you an option of repairing using Recovery Console by pressing “R” or continue with setup by pressing “ENTER”; press enter to continue with setup.
  • Setup will list all your disk partitions, highlight the partition where you want to install Windows, this is mainly partition “C”, press “D” to delete the partition, then press “L” to confirm.
  • Highlight the partition you deleted, and then press “C” to create a new partition, press “ENTER” to create the partition.
  • Press “ENTER” again to install Windows on the New (Raw) Partition you have created.
  • Format the partition using NTFS file system.
  • After format has completed, Windows will restart and setup will prompt you to boot from CD again. Ignore the message and let setup continue automatically.
  • Follow the next steps which will ask you to setup the system Time and Date, Network and enter a serial key, until setup finishes.
  • After setup has finished, Windows will restart and will welcome you for the first time; Microsoft Windows XP will have successfully been installed on your computer.
on Jan 07, 2010 | Computers & Internet
When i turn my computer on it loads but then a erro message comes up so i want to do a pc reset and i have looked online useing my laptop and it tells me when i see a blue dell splash bar come up to press...
The procedure is actually correct. but if your computer is fast you may miss it. try this, upon turning the computer on, start pressing the CTRL+F11 immediately. if you have reformated your HDD then most likely you've lost the recovery partition for the PC Restoration.
godspeed
Jun 23, 2011 | Dell Inspiron 531s Desktop Computer
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
I WANT TO BE XP ON MY LAPTOP HP PAVILION 2601TX REPLACE WITH WINDOW VISTA HOME PREMIUM.
Installation process Installing Windows XP can take up to two hours. To make the process more manageable, it has been broken up into several sections. When you are ready, install Windows XP:
Part 1: Begin the installation
1.
Insert the Windows XP CD into your computer and restart your computer.
2.
If prompted to start from the CD, press SPACEBAR. If you miss the prompt (it only appears for a few seconds), restart your computer to try again.
xp-setup-0-press-any-key-to.jpg 3.
Windows XP Setup begins. During this portion of setup, your mouse will not work, so you must use the keyboard. On the Welcome to Setup page, press ENTER.
xp-setup-1-welcome-to-setup.jpg 4.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then press F8.
5.
This page enables you to select the hard disk drive on which Windows XP will be installed. Once you complete this step, all data on your hard disk drive will be removed and cannot be recovered. It is extremely important that you have a recent backup copy of your files before continuing. When you have a backup copy, press D, and then press L when prompted. This deletes your existing data.
6.
Press ENTER to select Unpartitioned space, which appears by default.
7.
Press ENTER again to select Format the partition using the NTFS file system, which appears by default.
8.
Windows XP erases your hard disk drive using a process called formatting and then copies the setup files. You can leave your computer and return in 20 to 30 minutes.
Part 2: Continue the installation
9.
Windows XP restarts and then continues with the installation process. From this point forward, you can use your mouse. Eventually, the Regional and Language Options page appears. Click Next to accept the default settings. If you are multilingual or prefer a language other than English, you can change language settings after setup is complete.
10.
On the Personalize Your Software page, type your name and your organization name. Some programs use this information to automatically fill in your name when required. Then, click Next.
11.
On the Your Product Key page, type your product key as it appears on your Windows XP CD case. The product key is unique for every Windows XP installation. Then, click Next.
12.
On the Computer Name and Administrator Password page, in the Computer name box, type a name that uniquely identifies your computer in your house, such as FAMILYROOM or TOMS. You cannot use spaces or punctuation. If you connect your computer to a network, you will use this computer name to find shared files and printers. Type a strong password that you can remember in the Administrator password box, and then retype it in the Confirm password box. Write the password down and store it in a secure place. Click Next.
13.
On the Date and Time Settings page, set your computer's clock. Then, click the Time Zone down arrow, and select your time zone. Click Next.
14.
Windows XP will spend about a minute configuring your computer. On the Networking Settings page, click Next.
15.
On the Workgroup or Computer Domain page, click Next.
Part 3: Complete the installation
16.
Windows XP will spend 20 or 30 minutes configuring your computer and will automatically restart when finished. When the Display Settings dialog appears, click OK.
17.
When the Monitor Settings dialog box appears, click OK.
18.
The final stage of setup begins. On the Welcome to Microsoft Windows page, click Next.
19.
On the Help protect your PC page, click Help protect my PC by turning on Automatic Updates now. Then, click Next.
20.
Windows XP will then check if you are connected to the Internet:
• If you are connected to the Internet, select the choice that describes your network connection on the Will this computer connect to the Internet directly, or through a network? page. If you're not sure, accept the default selection, and click Next.
• If you use dial-up Internet access, or if Windows XP cannot connect to the Internet, you can connect to the Internet after setup is complete. On the How will this computer connect to the Internet? page, click Skip.
21.
Windows XP Setup displays the Ready to activate Windows? page. If you are connected to the Internet, click Yes, and then click Next. If you are not yet connected to the Internet, click No, click Next, and then skip to step 24. After setup is complete, Windows XP will automatically remind you to activate and register your copy of Windows XP.
22.
On the Ready to register with Microsoft? page, click Yes, and then click Next.
23.
On the Collecting Registration Information page, complete the form. Then, click Next.
24.
On the Who will use this computer? page, type the name of each person who will use the computer. You can use first names only, nicknames, or full names. Then click Next. To add users after setup is complete or to specify a password to keep your account private, read Create and customize user accounts.
25.
On the Thank you! page, click Finish.
Congratulations! Windows XP setup is complete.
Nov 02, 2010 | Computers & Internet
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
Hello, how to install windows xp?
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To install Windows XP, use the following steps.
Jan 08, 2010 | Computers & Internet
Downloaded drver for my printer. the add new printer wizard can't
Hi ...
If you have the driver CD that you recieved with your printer, follow the below steps to install the saftware:
  1. Turn on your computer.
  2. On your computer quit any open applications, including virus checkers.
  3. Insert the MultiPASS MP730/700 Setup CD-ROM into your CD drive. The [MP Setup] splash screen will appear automatically.
    1. If MP Setup does not start automatically, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    2. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  4. In the MP Setup splash screen, click 'Install MP Drivers'.
    Note: For Windows 2000 users, if Service Pack 1 or later is not installed, MP Setup will display a message and installation will be aborted.
  5. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  6. MP Setup will install some system files and may prompt you to restart your computer. If you are not prompted to restart, click 'Finish' in the MP Drivers Setup window and then proceed to step 7.
    1. If you are prompted, make sure radio button 'Yes, I want to restart my computer now.' is selected in the MP Drivers Setup window and then click 'Finish'. DO NOT remove the CD-ROM at this stage. MP Setup splash screen will open after Windows has restarted.
    2. If you had to restart your computer and the MP Setup screen is not displayed or you closed it, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    3. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  7. In the MP Setup splash screen, click 'Install MP Toolbox.'
  8. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  9. At the MP Toolbox Setup dialog box, click 'Finish'.
  10. Confirm the MultiPASS is turned on.
  11. Connect the USB cable to the MP730 and computer USB ports. Windows will detect the printer and proceed to install the driver files.
  12. Your MultiPASS includes additional software applications that you can install now or at a later date. To install the software, click 'Install Utility Software' and then proceed through each installation.
You can also download the drivers by visiting the below link and selecting your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035#DownloadDetailAct
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
How do i boot up a compaq presario off of win xp cd?
First insert your cd in the cd/dvd drive and then simply restart the computer and it will boot automatically. If it does not boot automatically then go to boot menu and select cd/dvd to the first in the booting order. It will then boot automatically.
Sep 20, 2008 | Compaq Computers & Internet
Open Questions:
Computers & Internet Logo
118 people viewed this question
Ekse
Marvin
Marvin
