Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Ice maker stopped working - have water on the door, just no ice - can you tell me steps for troubleshooting before replacing the entire unit
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 30, 2010
My ice maker quit working.
Ice not being dumped out because the heating element designed to slightly melt ice so arms can push it out is non functional and needs replacement. Cheaper and better to replace entire unit at nominal cost.
Feb 12, 2015 | Kitchen Appliances - Others
Freezer is icing up
The defrost assembly door is got blocked.
Reset the unit.
Unplug it from wall outlet foe approx 12 hours.Then reconnect and see.It will help.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Maytag Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Why is green light flashing
Its indication of overfreezed fridge or freezer unit.Or any door not getting closed properly.
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
The fridge is all working ok the freezer is all working ok but the ice maker is not working i have removed the tube that goes to the water part at the back and blew down it an it is not blocked
Hi and welcome to FixYa, I am Kelly
First off check the freezer door switch for operation. Depress the plunger and make sure the light goes off when the door switch plunger is depressed. Ligt stays on = bad door switch / no ice production as the door switch provides power to the ice-maker when the door is closed.
Here is a link to the steps on how to troubleshoot an ice-maker.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Let me just add that many ice-maker related problems are due to the freezer temp rising above 16 deg F. The freezer starts warming up due to ice build up on the evaporator coils and then the internal air-flow is blocked by the ice build up causing the temps to rise. Look closely at the back of the unit for any signs of ice build up.
If you see ice build up......
1. Unplug the unit
2. Remove the freezer contents
3. Place a fan directing air into the freezer for just over 2 hours. (Water mess!)
4. Clean up the excess water and restart the unit. (Add freezer content)
5. After 8 - 10 hours check for ice production.
If after doing the above you have ice production then most likely you have an automatic defrosting problem.
If it still does not make ice, the steps in the link above will isolate what has failed in the ice-maker.
Before testing the ice-maker using the steps in the link.. I recommend you peform a manual defrost with a fan. If 8 - 10 hours after the manual defrrost you do not have ice production,, use the link and troubleshoot the ice maker.
Thanks for choosing FixYa,
Kelly
Jan 31, 2011 | Refrigerators
Our ice maker stopped working. there is water
heatman101
hfdjdfh
May 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
Ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Apr 11, 2009 | Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
178 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
