Question about Emerson Televison & Video
I have a 720p 60Hz HDTV LCD TV, LC320EMX - when I push the power button both on the tv and remote the tv turns on and off and the picture never comes up - what can I do to get a picture
  • ndant2 Apr 30, 2010
    there is no sound, when you push the power button the tv turns on and then off immediately - there is no sound and only a brief appearance of "digital television" appears
  • 10,594 Answers
Symptom shows that back light inverter board got defective and need to be replaced.
Does tv give sound while screen is blank? If yes, replace back light inverter board.
Required back light inverter board is available in Shop Jimmy and need to be replaced by qualifier tv repairman, click above link to see image of board and price info.
Hope this info will help you.
Thanks.
Posted on Apr 30, 2010
  • Shahid Electronics
    Shahid Electronics Apr 30, 2010
    OK, then its problem of power supply board that will be replaced.
    Please call Shop jimmy for power supply board availability.
    Thanks.
My tv was on 1 minute and then the picture went out then the sound what could be a problem
Customer Reviews: Seiki 32" Class LCD 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/14978588
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
Customer Reviews: Seiki 32" Class LED 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/19717659
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
SEIKI TV SETUP - YouTube
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
25385173 My 32" seiki TV has no picture but sound
Dec 29, 2015 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
My TV has powered off and will not turn on. whats up
if the batteries are good in the remote and it wont turn on using the buttons on the tv, check the mains fuse in the plug failing that the power supply could be faulty and in need of repair
Feb 19, 2015 | Emerson LC320EMX 32 in. LCD HDTV
Proscan tv will not receive or recognize cable or video signals when all plugs are in as prescribed. Have removed power supply waited to attempt to clear it. Restarted and still get no signal message. We...
Here are a few ideas:
  • The No Signal, No Source or No Input message will appear on your television screen when the television is not receiving a signal from your Digital Box. This is often a result of either the Digital Box being powered off, not being properly connected to the TV, or if the TV is set to the wrong input.
  • Press the "TV/VCR" button on your remote control if you are experiencing no picture. This button will allow you to toggle between TV and VCR screens and may solve your display problem.
  • Make sure your cable box is turned on.
Jan 21, 2018 | Shopnbc Proscan 32" 720p 60Hz LCD HDTV w/...
The buttons board on my emerson tv got wet and now when i turn my tv on it keeps acting like a button is being pressed
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Mar 21, 2014 | Emerson 29" LED 720p 60Hz HDTV | LE290EM4
I have LN32D403 32-Inch 720p 60Hz LCD HDTV sumsung tv but it can not read my Toshiba hard drive i want to know what type of hard drive i can use in it thank u
Hi there, unfortunately there can be a problem with power insufficiency... if you have two USB connectors side by side on the back of TV set , please use Y Usb cabel and connect both in TV set and the other end to HDD. Or if your HDD comes with external power supply ac adapter connect it first. Then try again.Tnx
Sep 17, 2013 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
Remote does not control tv
check the batteries or the senser on the front panel of the tv....but first swith on the camera on your cell fone and direct the senser on your remote to eye of the camera then press any button the remote.if the remote is okey you should see flashing light on your cell fon screen
Sep 20, 2012 | LG 26LG30 - 26" Class / 720p / 60Hz / LCD...
LD260EM2 - Red light on but tv will not power on
PULL THE COVER THERE IS A FUSE THAT MAY BE BLOWN INSIDE
Sep 12, 2012 | Emerson 26" Class LCD 720p 60Hz HDTV and...
Sansui hdlcd185w shuts down after about 3 seconds
My sansui LCD tv is getting on after plug in to power supply but it is not getting on after switching on the remote/tv ,display is not coming pls help me
Sep 01, 2012 | Sansui 19" Class LCD 720p 60hz Hdtv,...
Televison & Video Logo
59 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
