Sound level goes up to highest level by itself. Using the remote or the panel buttons we can turn it down but then it immediately run right back up. Tried holding the button down but after setting at a comfortable level it runs right back up while holding the button. Can this be fixed?
Hi pono i would say exactly what Scorpionakku has said. Unless you have some knowledge about the internal parts of a television...Let me know if this is the case..
Your remort is short
thats y this problem occures take ur remot your nearest electonics shop tell him i want a same model no of remot
they will give u same remort & your problem will solved
or do one ting open your remot clen form the dust see your key pad is damged so if get a pad then replace the pad
Step 1:
Check the owner's manual before consulting other sources. Often, the possible problems are laid out right there, along with a troubleshooting guide.
Step 2:
See if the television manufacturer has a Web site with troubleshooting tips or FAQs.
Step 3:
Check all the connections - AC plug into the wall, cable television connection, input and output cables to other machines such as VCRs. Unplug or disconnect them, then plug them in again.
Step 4:
Look in the fuse/circuit box to see if the switch for the television's room is flipped, meaning that a fuse blew. If it did, flip the switch back to reset the fuse.
Step 5:
Check the remote control and replace its batteries if necessary.
Step 6:
Adjust the television controls, following advice in the manual. Incorrectly set controls can cause problems like sound but no picture and picture but no sound.
Step 7:
Test the setup of the cable television or VCR hookups by referring to their manuals. If you can identify which item is causing the problem, you can call the company's customer service number and talk with a technician.
Step 8:
Clean the parts of the television that are visible, but don't dig into openings. Make sure the television is unplugged from the outlet when you clean it.
Step 9:
Double-check the antenna if you have one. Replacing it or pointing it in a different direction may help solve the problem.
Step 10:
Take the television for professional service, if necessary. It's better than nullifying the warrantee or ruining the machine by attempting repairs yourself.
HI,
Here are few troubleshooting steps you can try:
ONE: Disconnect the power cord for 4 hours. Then when you power it back
up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand
on the back, side, top, etc., to see if there are loose connections or
cold solder joints inside that are acting up. If so, the banging should
knock them back to normal and the set should restore. You might have
to use some creative banging and some have had to put a book or
magazine under one corner to torque the chassis enough to get it to
work reliably.
If this does not solve your problem then the problem is with the circuits inside your TV therefore you will need a technician to fix this problem.
Goodluck,
Please don't forget to rate the solution.
Dear Pono ,
its mean the touch buttons circuit's of you Television needs servicing, Genrally this kinda problem generated by the carbon rust on circuits. my suggestion is just call a Authorised service engg. to fix this problem.
cheerup
Can you give us the make and model of the tv so that we can better help you, thank you
if you take the batteries out of the remote, does this still happen? If it doesn't, then the remote is your problem, if it does, then we will have to look into this more, please let me know, I'm here to help.
Glad you were able to solve your problem. Please let me know if you have any further questions or need any more help.
Have a Great Day
(I kinda wish I could be in Hawaii, never been there)
An expert wanted the make and model with the sound problem I am having on my GE 35GT695 TV. The sound always runs back up to loudest no matter where we set it via remote or panel buttons.
I will accept your solution as soon as I can try it out. I live in a remote sort of area in Big Hawaii (we do have cable) and will have to travel into town to get a new remote. If this works, your it and I will log back on to accept.
Yes, it still happens when we removed the batteries from the remote. But....inadvertently we followed a previous post here. We had unplugged the TV to plug in another. Today in cleaning the panel buttons and check it out again we plugged it back in and we hit the remote from the other TV and it turned our GE on. Now it seems to be working fine and with the RCA remote. Go figure. Now I have to figure out who to give credite for on this one.
