Question about GE JBP62BM Kitchen Range
Stove makes a 'pop/puff' sound, sparks shoot out and the breaker blows. First it wa just the front right burner, then we re-set the circuit breaker and tried other burners and it did it again. It is a GE Model J BP62B M2WH model electric smooth cooktop range. Have had no previous problems.
5 Suggested Answers
SOURCE: GE Spectra - burner pops & blows breaker
Either the burner has gone bad or the limiter on the burner.
Posted on Jul 12, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
DeBruce
  • 145 Answers
SOURCE: SMOOTH COOKTOP DISCOLORATION
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Posted on Aug 24, 2009
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
Frigidaire oven trips the breaker w/loud popping spark behind the stove when it is turned on. With breaker reset, the stove was heating up even though it was off. Can it be fixed? I unplugged it.
sounds like someone spilled something down the back of the oven. you wuill have to open the back and trace the mains lead and see were it leads amd if it needs cleaning. rcds trip when water or steam hits the mains.
Apr 25, 2018 | Ovens
A pop & breaker tripped.retripped the breaker and neither the broiler nor the bake oven element in kenmore stove won't work
Sounds like you have a short in the wiring some place. A short will cause the breaker to blow. There are fuses in most electric stoves that blow as well usually back of the clock area.
Oct 04, 2015 | Kenmore Kitchen Ranges
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
My Fridgidaire FEF366BCC just popped my breaker
This sounds like a main control problem. More specifically like one of the relays is shorted. You will need to acess the main control and carefully inspect it for any burn marks. If you don't see any disconnect the main power supply wire going to the main control. Then plug it back in if it trips the breaker the problem is in the power cord or wiring from the cord junction to the main control. If it does not trip the breaker the problem is the main control. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Jul 21, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Stove power is out
Turn off the power.
Remove the rear panel on the range.
Repair the broken wire at the wiring terminal.
Install a wiring strain clamp at the terminal block to prevent this from happening again.
Mar 25, 2009 | Electrolux Kitchen Ranges
Stove is tripping circuit breaker Two burners stopped working properly (only get slightly warm). Switched the coils to the other side and the other side is still working. Looked underneath and saw that...
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Mar 04, 2009 | Jenn-Air Expressions AC110 Electric...
Circuit breaker popping when stove top/ oven is on
thats how fires start when fuses keep blowing. Just use one at a time. Its probably over loading the fuse you may need a bigger fuse block. Call a local handy man if you havent already
Jan 03, 2009 | Kitchen Ranges
Jul 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE JBP62BM Kitchen Range Logo
108 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
