Question about RCA Televison & Video
RCA -rear projection TV, D61W130 shutting down after warming up
After the set has been on for a short while (varies from 1/2 hour to 2 hours) it produces a loud audible crack or surge and shuts down. It restarts and comes back on 30 seconds later. This is intermitted, but once it starts it continues with an increased frequency. I suspect something is overheating and shutting it down.
What to fix and how to do it - thanks
  • RCA Master
  • 19,396 Answers
Hi.
Althought RCA rear projection TVs have from one to three temperature sensors, mounted near to the lamp and on digital board, the problem here is not overheating.
When the problem is overheating, the TV will not restart by itself 30 seconds later, but it will stay on standby for an increasingly long time.
If the cracking noise is coming from the speakers, then it can be a problem on the audio circuit board. It can be caused by a faulty component (IC or capacitor) that gets charged causing the problem more frequently while the component holds charge.
When you turn off the TV for one hour, the faulty circuit will discharge completely, and will be able to work for longer time before crashing.
If the noise sounds like caused by impact, it can be caused by a faulty color wheel.
The fault is not common and the TV must be taken apart and inspected by a technician to find the fault.
As a first step I suggest calling RCA at the number listed on the owners manual. If they can offer an affordable repair, better getting an on site technician to work on TV.
You can also get a technician in US by using the Fixya directory:How to get the contact for a qualified technician.
Regards.
Posted on Apr 30, 2010
Rca tv troubleshooting
the CRT focus caps need change all 3
Nov 28, 2013 | Televison & Video
I have a 56 inch rca rear projection tv and after two hours starts turning of and on for about half hour and then turns off. when we turn it back on it shuts off and comes on fast and then shuts off....
Those type of tv sets get unusually hot at times. Could be a heat issue. Power flow at night is the best. If it's still turning off then, it must be a dust or heat issue.
May 08, 2011 | RCA D56W20 56" Rear Projection Television
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA Scenium d61w130 turns off then on
I installed a small cooling fan in the back ot the TV. It was overheating. Fixed the problem.
Nov 22, 2008 | RCA D61W130 61" Rear Projection Television
Rca scenium turns off and on
I had the same problem with mine. It was overheating. I installed a small cpu cooling fan on the back of the unit. No problems since. Good luck.
Mark
Nov 08, 2008 | RCA D61W130 61" Rear Projection Television
Coolant leaking
the coolant has done 1 of 2 things. (1) most likely it has shorted components on the circuit board. (2) also very likely that the affected tube has cracked without the coolant and thereby shutting down the set.
Aug 22, 2008 | RCA D52W19 52" Rear Projection Television
RCA D61W130 tv
this unit has two tuner modules. one is the main tuner and the other is the slave or the pip tuner. it would apear from your description that the main tuner has failed. it is possible that this can be replaced.
Jan 28, 2008 | RCA D61W130 61" Rear Projection Television
My TV turns off then turns it self back on 3-5 minutes later. We are told it is the small signal board?
rca? d61w130 itc222 ..does the unit flash green led.
itc222 shut down if the processor detects a problem. can be many different things. horizontal output is first thing to check. any sounds, chirps, smell... did it ever work
Dec 19, 2007 | RCA D61W130 61" Rear Projection Television
Televison & Video Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
