Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
LCD causes self-test to fail
Got a pair of Dell 1702FP monitors.  Was able to fix one.  Second one is more difficult.
Monitor lights flash, inverter does not power up.  I went inside, did some part swapping between the monitors.  Can confirm that inverter is good.   When I disconnect the upper right bundle of wires that goes to the LCD itself, the monitor's power lights behave normally, backlight comes on OK.
When I reconnect the LCD panel (pixel control, not inverter), the monitor seems to fail a self-diagnostic and the lights blink, no backlight.
What are typical problems for the LCD panel itself?  Are they fixable?
  • Dell Master
  • 1,684 Answers
If the 3 lights are flashing then the problem is afew blow capacitors on the video driver board. We have a step by steprepair guide posted on our web site at: www.ccl-la.comIf you can solder then you should be able to do the repair. If youdon't want to do it we do offer a repair service for $30 plus returnshipping. let us know if you have any questions about the repair, youcan contact us at the address below.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 10, 2009
  • 286 Answers
Looks like you have a shorted IC ot transistor on the LCD layer of the panel.
If you remove the screws from the back of the panel and look underneath, you will see the circuit the main board plugs into. Usually there are a few components on this pcb that can go bad. Replacing them is a little hit and miss. If you can identify the component, you might stand a chance. I had a unit do this, and when I looked at the lcd pcb there was a shorted smt transistor. It was burnt, but I was able to remove it without damaging the board.
I managed to replace it twice with two similar transistors, but the panel still caused the power circuit to cycle when I plugged it in. Although I couldn't find any other shorted parts, the small smt ICs on the board could have had internal shorts, or the transistors I used to substitute were completely wrong for the circuit. Since the original transistor was burned, I could not identify it in any way.
The only hope for your monitor is to identify and replace the bad smt component on the LCD board, or replace the lcd layer itself. I've done this a few times, but it requires another of the same panels, one with a bad backlight perhaps. If you are careful enough, you can remove the metal frame assembly from the panel (there are usually four screws, two on each side). You will have to "unsnap" the outer frame from the inner frame all the way around the outside.
Do this to both panels, and place them face up on a desk or bench. Carefully unwrap the ribbon cable and remove the entire lcd layer. Do this a second time, only place the working lcd layer over the working backlight assembly. Make sure the lcd layer seats snugly in the frame and wrap the ribbon cable over the top. Reinstall the outer frame. You have to make sure everything stays aligned as you snap the outer frame back into place. Reinstall the screws. Now you should have one perfectly good lcd panel. Keep an eye out for a panel with a bad backlight.
Posted on Mar 27, 2008
Monitor model 1702FP wont start. lights keep cycling
The flashing power and signal lights are caused by 4 bad capacitors on the main driver board. Here is a link to information showing where they are and how to replace them.
http://www.instructables.com/id/FREE-17%22-LCD-Monitor---How-to-do-it%3F/
Sep 23, 2012 | Dell 1702FP 17" 1280x1024 .264mm Midnight...
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
My dell ultra sharp 1702 monitor blinks for quite awhile before starting up when I turn it on...?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell e152FPB LCD monitor backlight power problem
Check the four transistors (c5707/5706) in the inverter section for shorts, board looks like this? http://www.lcdrepair.us/e152-e153fpb-inverter-power.html
Feb 20, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor comes on and displays for a second then goes blank.
New monitor? Does old monitor still work? Did the monitor ever work? did the computer ever work? is power light on computer on? is power light on monitor still on?
Oct 15, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Dec 24, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Display works - but only for a plit second...
Lower your resolution on your computer. Usually when that happens the resolution is set higher than what the monitor can support. Lower the resolution and try again.
Jul 25, 2007 | Dell E173FP 17" LCD Monitor
Digital not working
The latter part of this post seems to confirm that the problem is inside the monitor, probably a failure on the signal / video board. You might also look for damage to one of the connectors. Otherwise, if your manual shows some settings or a rest, that might be the issue. But the fact that the self-test does not work leads me to believe that the unit needs a new a signal / video board.
Jan 06, 2007 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell 1702FP Blank Screen problem
Hi there, I had the same problem on two Dell 1702FP monitors and I solved them, now I am using one as an LCD TV and it's been working great since then. Solution: replace surface mount capacitors, 10uF 16V value, C604 and C507... I created an instructables web page for it, so please follow the link below: http://www.instructables.com/id/ELWXF03NV6EQZJIZM2/ Enjoy it! Koray.
Feb 18, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
178 people viewed this question
Alun Cox
