Question about Panasonic KX-TG5653B Trio Cordless Phone
Base unit always says IN USE
It's practically unusable. Base unit says In use while all the handsets have been turned off. Is there a way to reset the entire system? I tried removing batteries and disconnecting the base unit but that didn't help
    Genius:
  • 1,554 Answers
Take the base to a friends house and plug it in.
if it still says in use then its not your line.
and you will have to get panasonic to repair it , likely a lightening hit.
Posted on Mar 25, 2008
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
Tip
Fixing the handset link to base unit of Panasonic KX-TG4500
After the base unit died I was able to restore power by switching out the power adapter of one of the handsets with the one on the base unit. However, when the power was restored to the base, none of the handsets that previously worked were getting a dial tone. I could only use the phone from the base unit. To fix the handsets I first reset the base unit by pressing the reset button with the tip of a pen on the bottom of the base phone then momentarily removed and reinstall the battery on each of the handsets to allow each to reset individually. In doing so, I got the dial tone back on all previously linked handsets without having to reregister them.
on Mar 23, 2010 | Lands Phones
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
Jun 25, 2011 | AT&T E5640 Phone
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
Phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
Apr 29, 2009 | Uniden Cordless Phone
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
Searching is displayed on handset and Y icon is blinking, looks like a twig sign, have tried move closer to base station, base station is on reset unit restart handset reg, have tried all but gets to...
Turn base around and find the area which says pager/registration. Push this button after you set internally the handset registration.
Menu/H set settings/Reg. Handset
Dec 03, 2008 | Lands Phones
Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
May 03, 2008 | Uniden Cordless Phone
Panasonic KX-TG5653B Trio Cordless Phone Logo
77 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
