I have an old program that has a document on it that was to be printed with either word or word perfect. When I attempt to open it now it does not recognize word 2007 that i now use. Any suggestions?
  • shoodbwurkin Apr 30, 2010
    thanks for the help. It worked
    Brigadier General:
  • 7,191 Answers
Please let us know more details like the file extension of the document (.doc,.wpd, others..)
You can try to open this document using the Microsoft Word Viewer which can be downloaded from here
Word Viewer can be used to view and print the following file types:
  • Word Document (*.docx)
  • Word Macro-Enabled Document (*.docm)
  • Rich Text Format (.rtf)
  • Text (.txt)
  • Web Page formats (.htm, .html, .mht, .mhtml)
  • WordPerfect 5.x (.wpd)
  • WordPerfect 6.x (.doc, .wpd)
  • Works 6.0 (.wps)
  • Works 7.0 (.wps)
  • XML (.xml)
  • Hope this solves your problem. Thanks for using FixYa.
    Posted on Apr 30, 2010
    I have Broderbund Print Shop version 11. How can I open docs on windows 8? Leanne
    Sorry I don't think there is a solution. Windows 8 doesn't run version 22 either. I did load version 23 on it for a while but it was limited in size of document. I had to remove it. Am looking for another product now. I guess we have to have an old computer for an old program.
    Nov 27, 2012 | Broderbund Print Shop Pro Publisher 11
    The printer says Load MP feeder B5. how can I fix this.
    Several options here:
    1st - cancel any documents in the print queue. and print off a report of some kind via the menu button on the machine. if that prints correctly then it either a software/ print driver setting issue.
    2nd - If that prints out correctly open up a text pad/ notepad and attempt to print that if the message pops up it's very possible the paper handling has been miss-configured within the print driver.
    Now if the document does print out fine, the original document you were attempting to print is set to a B5 paper size. If that's the case pending on what program you are using you will have to change the paper size to you choice of paper your using.
    3rd - open up the paper tray and confirm it's set to letter or legal pending what type of paper you have in the tray(not the manual feed tray). I highly doubt it's the tray however as B5 setting would not allow any type of normal paper to be loaded.
    4th - on the machine hit the menu button -> paper menu -> confirm that the paper type/ size and source are configured correctly.
    Link to the user manuals for this machine : click here
    Oct 19, 2010 | Lexmark T632 Laser Printer
    I cannot print color grahics or pdf documents. Operating system is windows 7, and I'm using the postcript driver for the printer.
    Do you have Adobe Acrobat installed? You need the program in order to open and/or print PDF documents. If you don't have it the program is available for free on the internet. If you do have it, make sure that your version is the most current.
    Then try this!
    Change or update the driver to the regular printer driver. Don't use the postscript driver choice in your control panel. If you already have the regular printer driver installed and are using the postscript driver as the "default" then follow the instructions below to correct the problem.
    Go to your control panel. Open printers. You will see all of the printers and drivers installed. Right click with your mouse on your regular printer. You will see a drop down list of choices to pick from. Choose "set default". Then close and save your choice.
    Then open Adobe Acrobat and find a pdf document and try printing. This will solve the pdf document printing issue.
    Changing your default printer to the correct driver should also solve the problem with inability to print color graphics too. If it does not solve the problem, please re-post and elaborate about what your experiencing when you attempt to print a color graphic and I will try and help you.
    Sep 27, 2010 | Office Equipment & Supplies
    I want to print a new document but the old document always coming out
    This is because - you had tried to print the old documents and that printing sessions were not completed and the documents are in printer buffer. You may switch off the printer - go start - settings - printers and faxes - double click the printer name - you will find some printing requests are there - delete those. Now switch on the printer. Try to print the new document, it will print perfectly. If same thing happen again you do the same steps. But if this problem repeats - you should re-install the operating system.
    Jun 12, 2010 | HP DeskJet F4280 All In One Printer InkJet
    Prints documents straight from PC, but printing from internet bad
    Try to save the save the page into single file then try to print.
    Aug 19, 2009 | Samsung CLP-300N Laser Printer
    Can't print Word Perfect documents on my Lexmark 1300
    Make sure you have all the recent microsoft updates.
    If it still won't print you can use OpenOffice (Free to use and download) to open your documents with and maybe they will print from there. Using Open Office may change some formatting, but you can usually fix that pretty easily.
    Download Open Office
    Dec 30, 2008 | Computers & Internet
    Not printing or scanning
    For this issue try uninstalling the drivers compltely and resintall using the CD which came along with the printer
    Jun 17, 2008 | HP PSC 2175 All-In-One InkJet Printer
    Computers & Internet Logo
    David Payne
    David Payne
