Question about Video Game Consoles & Games
When I start the xbox after I put the game in error E71 comes out.On the console's ring the lower right light turns red,and the screen says cant read disk restart console. Then the E71 screen comes out again.
  • 45 Answers
Your laser is dirty buy a cd lens cleaner and hopefully this will solve the problem
Posted on Mar 25, 2008
I had the cant read disk error so i cleaned the lense, then it did the 3 red lights after that so i got a new dvd rom drive switched out the boards. and i still get the 3 red lights. what else can i do?
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance..
all the best.
click here to download
Dec 07, 2010 | Microsoft Xbox 360 Console
I have an xbox 360 that pops up with the 3 red lights on the front and every now and then the e71 error. How do I fix this problem myself?
Nobody is 100% sure what causes this error but it Most likely relates to dashboard and console updates. Also, the problem appears to arise from gamers incorrectly flashing their hardware or doing botched firmware hacks which then prevent the system from functioning correctly.
Have you recently updated your Xbox 360 in anyway, or have you (or anyone else) attempted some form of firmware hack or flash? If so, this is probably the cause of the e71 code on your Xbox, however, it could also be completely random. If you call microsoft they will most likely tell you to9 just reset but that is only a temporary fix and you still have the problem of annoying freezes which will get worse and worse. Fixing the Xbox e71 is quite tricky. First try these methods,
1) switch off the console. With the console switched off, press and hold the sync button (the small white button that is used to search for wireless connections). While holding the sync button, switch on the console by pressing the power button and do not release hold of the sync button until the console is fully booted up. During the booting up of the console, any failed updates will be cleared allowing the console to run normally once again and thus eliminating the xbox 360 e71 error.
Another similar way is to
2)Hold the wireless connection button on your controller down with the 360 off. It's the little white button between the shoulder buttons. It's what you used to set up your wireless controller with your 360. While still holding the button, hit the XBOX logo on the controller to turn on the XBOX. Do not let go of the white button. After it's fully started up, you can let go. this reverts you back to your last update.
Or if nothing else seems to work you could try completely resetting your Xbox 360. To do this,
3) First enter the dashboard, go to the right-most column, go and press "Initial Set Up" then follow the instructions on screen. If you cannot access this screen due to the e71 error on your Xbox 360, you can try holding the "Y" button on your controller as you switch the console on. This will enter the same process, and restore default factory settings. However, there is still a chance that this might not work.
There are guides available online for less than $30 if you cant seem to get it fixed but make sure you get one that explains all errors as most only tell about the red ring of death.
Hope this helps
Nov 29, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Red light come on xbox360 what is the problem
If you get red light around your xbox power button the you have red ring of death. This is when your Xbox has overheated. While im not all that famlier with Xbox I have read there is a 6 cent fix (cause you use 6 pennies) You would have to read up because as I sid before not great with Xbox. I'm sure microsoft would do it to but hey if you good with tools 6 cents sounds pretty cheap.
Im sorry for your loss
Good Luck and Happy Gaming-Koscoe
Oct 13, 2010 | Video Game Consoles & Games
When i put a game into my xbox to play it it comes up with this writing in japanese and german and sais error E 71 can you help i no it is not the red ring of death bacause it only has one red bar ???
The error code E71 with one red light flashing on the Ring of Light means that the console is having trouble accessing the memory device which is the hard drive. what you can do is to remove the hard drive and power on your console, if it starts up fine it means you need to replace the hard drive. If it does the same thing without the hard drive, well your console is having hardware failure inside and needs technical repairs, you contact Microsoft and have it fixed for free if it is in-warranty.
Jun 01, 2010 | Microsoft Xbox 360 Arcade
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
My xbox 360 has error 74
The E74 malfunction is a problem believed to be associated with the system's video output cables and/or hardware scaler chip. The problem involves unusual screen patterns, the appearance of an on-screen error message, and finally a flashing red light in the lower right quadrant of the power ring. When a system suffers from the failure the on-screen message reads "E74 System Error. Contact Xbox Customer Support."
You could send it in to Microsoft of you can follow the steps as outlined in this You Tube video.
Mar 21, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Lower right red light flashing with error e74 on screen
lower right is a hard drive failure> Take the HD off and try to play without it. Then put it back on.
Jun 28, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
