Question about HP Pavilion Ze4900 Notebook
My monitor went all black but I kind of can see through the darkness does that mean to get an external monitor??
    Sergeant:
    Novelist:
  • 172 Answers
Hi nickmale09. The answer is yes. because getting a new screen + labor can be pricey. You can connect an external monitor and pressing FN + (either F5 or F8 twice, it's the one that has the little monitor), and you will get the screen on the external monitor. I hope this helps and please dont forget to rate and provide positive feedback for our free support today. Thank you :D
Posted on Apr 30, 2010
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
Gateway 5150 - computer screen stays black, screen works fine, just very very dark - can't seem to adjust luminosity?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 09, 2012 | Computers & Internet
My screen went black
most of the cases is due to the inverter.. the inverter is located inside the notebook.. worst case is due to the main board.. try hooking up to external monitor, and if there is a display.. then most probably is the inverter faulty..
May 23, 2010 | Acer Aspire One PC Notebook
Dell Inspiron 1521 laptop monitor is dark.
It is a posible LCD problem, Might gone defective.
First trouble shooting is to turn off your laptop completele and the remove the battery and the charger and any accesories connected on yur lap top. Then press the power button for 1 minute. It will reset the settings of your laptop to default if you accidentally press the command for the hotkey to turn off the built in monitor and enabled the extended monitor.
If the issue persist it means it is an issue with the LCD and needs to be replaced.
Mar 28, 2010 | Dell Inspiron 1521 Notebook
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
HP DV 1000 screen goes dark after boot up. Plug in external monitor and it works fine. Toggle between internal and external and I can get the laptop monitor to come back on for a few min. Turning...
Your laptop's monitor went bad and needs to be replaced. I had the same problem on an IBM laptop I had. Replacing the monitor costs between $120-220.
Apr 15, 2009 | HP Pavilion DV5-1000US Laptop
Laptop monitor is black
The fastest way to eliminate the video section of your PC is to use the VGA port with an external monitor. If you can get any kind of video, then the problem is narrowed down to either the fluorescent backlight itself or the inverter that supplies it with high voltage; neither of these have any influence on the video output to an external monitor. The LCD section itself can't really fail at once since it is made up of tiny pixels and while it isn't uncommon for indivdual ones to fail, the likelihood that all fail is very remote.
The problem is; without some technical skills, it would be tough to pin it down to one of these two. The backlight tube is a specially formed fluroescent and if it appears to be blackened at either or both ends, then the tube is dead. If it appears pristine, then the inverter is dead; this is normally a small board apart from the main board and not too bad to replace.
Accessing the backlight is of varying degrees of difficulty and if it isn't done carefully, you could damage the LCD portion.
If it seems to boot OK, if you peer at the screen from several shallow angles, you should be able to see some 'ghost' activity on the screen.
Mar 10, 2009 | HP Pavilion dv6000z Notebook
Display after rain went black
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is to have the LCD panel replaced.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 6400 Notebook
HP Pavilion Ze4900 Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
