Question about Mtd Products Yard Machines 158CC Tiller
I have a MTD yard machine rear tine tiller. Goes forward and reverse but tines wont rotate. How do I fix?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Posted on Jul 01, 2010
  • mcclr1 Aug 14, 2011
    I too had one that would pop out of gear while tilling. You could hold the lever in but that would eventually bend the shifting fork in the transmission and it would then jump out of the groove in the shifting sleeve. I put new pins on the shifting fork and reinforced it so that it would not bend so easily. It worked fine for a few minutes and then jumped out of gear again. A friend led me to the real solution. The shifting fork is not supposed to hold the shifting sleeve in gear. It is only supposed to slide the shifting mechanism and the detent spring and ball are supposed to do the holding work. I once again repaired the shifting fork but this time ordered a new detent spring part number 932-0863 and a new detent ball part number 741-0862. They cost $4.40 and that was the solution to the problem. I would also order a new shifting fork if yours has been bent. The new ones are a different design that has more reinforcement. It is a lot of work to tear into these so buy the new parts the first time. I was getting adept at the process after doing it three times.
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
The cluch doesn't work. The gear pointer doesn't
Do you have a model number? Front tine or rear tine? I will try to help you.
May 29, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Sep 28, 2008 | Mtd Super Bronco Rt Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
1,352 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
