Question about GE PFS22SBSSS Stainless Steel French Door Refrigerator
The control panel on my GE profile refrigerator will not stay lit after I adjust the temp settings. It's brand new. Any ideas?
  • 1462 Answers
SOURCE: GE Profile Arctic Side x Side Refrigerator PSC23MGNA
check that compressor is not cutting out on overheat and hence cooling stops. feel compressor when it has been running for some time and see if it over hot
Posted on Jun 18, 2007
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Posted on Apr 25, 2008
johnychel
  • 796 Answers
Its just blowing warm air in the freezer section?
No frost build up on the inside back freezer panel?
This link will help you troubleshoot it:
http://www.applianceaid.com/refrigerator.html (http://www.applianceaid.com/refrigerator.html)
Posted on Jul 01, 2008
  • 33 Answers
SOURCE: Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Posted on Nov 29, 2008
  • 74 Answers
SOURCE: Ge Profile Freezer not working
Main pcb failure but just check the wireing at the bottom of the freezer door as it can affect the control system
Posted on Feb 26, 2009
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
See all GE PFS22SBSSS Stainless Steel French Door Questions
GE PFS22SBSSS Stainless Steel French Door Refrigerator Logo
353 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
