Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD5000ME power up but can't see it's folder.
I have a WD5000ME, It was working fine. I was transfering files from my laptop to my hard drive when I received a message that the path couldn't be found anymore. Since than I plug the hard drive in the usb port, the light form the hard drive goes on, but I can't see it in my computer anymore. When I ask to "Safely REmove mass USB storage"I only see the word WD, don't see the memory drive itself.
    Sergeant:
    Novelist:
  • 172 Answers
Hi gbenez. Either the enclosure or the hard drive is going bad. (Sorry to be this harsh). What I recommend is DONT TRY CHKDSK or any test utility because it will stress the hard drive making things worse.Remove the hard drive from the enclosure (it could be a little tricky) and then trying connecting the hard drive internally to your computer. If it's a laptop either get another enclosure and try again, but I rather use the SATA on a desktop motherboard, not the USB. If you dont have a problem connecting the hard drive internally do a backup 'pronto' to another hard drive, you may not have much time.If you still have the same problem, then you are sure it's the hard drive. I hope this helps and please dont forget to rate and provide positive feedback for our fast-free support today. Thank you :D
Posted on Apr 30, 2010
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes
USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a
USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all
USB cables are equal even though they should be)
3. Do not connect through an external
USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the
USB "Safely Remove Hardware" option. If you don’t do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to check the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. Ensure that you have set removable drives for "quick removal" or that you use the "Safely Remove Hardware" option often shown on the lower toolbar. It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! And knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click of Death"
Hope this gives you the information you need
  • 2 more comments
  • Project NOMAD
    Project NOMAD Apr 30, 2010
    On rare occasions it is possible that the PSU for the drive can also fail.
    This is quite rare on the better quality drives but is still a possibility.
    if this does happen it may be possible that the PSU supplies enough power to light the LED on the drive but not enough for the drive itself to operate..
    In those instances any commonly available replacement with BOTH the same voltage and current rating will work
    eg. 5V 700mA as may be written on a drive or the instruction / specification sheet that came with it.
    NEVER use less than the req voltage and never use less than the req current although you can use a larger rated current. eg. 5V 1000mA would be fine and last longer than the original PSU.
    If the drive does not show up in your hardware lists then using software of any description to try recover files is a total waste of time.
    If the drive is still under warranty or you don't mind opening it up it is not uncommon for the connection between the interface board and drive to have worked loose esp. if the drive has been moved a lot.
    In those circumstances opening the drive enclosure and removing the connection and then re-connection can also fix quite a few issues.
  • Project NOMAD
    Project NOMAD May 07, 2010
    Was the information of any use ?
  • Project NOMAD
    Project NOMAD Nov 03, 2011
    online 4u adipex advicer baccarrat blackjack bllogspot booker byob car-rental-e-site car-rentals-e-site carisoprodol casino casinos chatroom cialis coolcoolhu coolhu credit-card-debt credit-report-4u cwas cyclen cyclobenzaprine dating-e-site day-trading debt-consolidation debt-consolidation-consultant discreetordering duty-free dutyfree equityloans fioricet flowers-leading-site freenet-shopping freenet gambling- hair-loss health-insurancedeals-4u homeequityloans homefinance holdem holdempoker holdemsoftware holdemtexasturbowilson hotel-dealse-site hotele-site hotelse-site ****** insurance-quotesdeals-4u insurancedeals-4u jrcreations levitra macinstruct mortgage-4-u mortgagequotes online-gambling onlinegambling-4u ottawavalleyag ownsthis palm-texas-holdem-game paxil ***** pharmacy phentermine poker-chip poze ***** rental-car-e-site ringtones roulette shemale shoes slot-machine texas-holdem thorcarlson top-site top-e-site tramadol trim-spa ultram valeofglamorganconservatives viagra vioxx xanax zolus
  • The answers by Project Nomad / bob_computer are to be considered copyright 2011 and property of
    R. Humpleby
    Use without prior "written permission" is no longer allowed.
    This property is no longer shared with Fixya and its associates / affiliates
    Reason. account termination.
I also have same issue and dont show any thing on my computer screen what i only do is that i only change the cable which connect my WD external HD with my laptop it work fine . kindly check it out if this work the simplest way and usefull.
Posted on May 12, 2011
Transferring files via external hard drive to new computer
You just need to connect the external hard drive to the new computer. Once it has connected and Windows recognizes the drive it should pop-up with the window asking what you would like to do (select the option to View Files). Also at this time open the folder on the new computer that you want to store the back-up files in. Make the external hard drive folder and the new computer folder sit side-by-side. Then while holding down the CTRL button on the keyboard click each file you want to move. When you are done selecting them - right click on any of the file selected and on the pop-up menu select "copy". Now go to the folder on the external drive and right click the mouse again and from the pop-up menu select "paste". This will just copy the file, that way you can keep the files on 2 different hard drives in case something happen to 1 of them.
Austin
We-Supply.com
Jul 22, 2013 | Memorex Ultra Traveldrive - 160GB USB Hard...
Trying to transfer data from an old harddrive i have (maxtor, diamondmax plus 9 80 GB ATA / 133 HDD) to My HP laptop
Install the hard drive into an USB hard drive adapter case the plug this USB hard drive into the USB port in your laptop. The laptop will see it as an external storage device, open the various folders and copy the files to your laptop.
You can delete any unwanted files off this external USB hard disk and use it for backups and file transfer.
Mar 14, 2013 | Computers & Internet
Does not allow transfer of files or pictures
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
Click on the "My Computer" icon on your desktop, and open the external hard drive.
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the photographs.
usually in my documents my pictures or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my pics 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the photo file, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
Sep 27, 2012 | SimpleTech Signature Mini 160GB External...
I have transcend storejet elite 500GB. It works well, but the thing that I don't satisfy is that when I transferred the data from my laptop to it, it was not able to transfer the data, it sow an...
Greetings,
That's a good one :). Basically, I believe it's complaining about the path of the file, not necessarily the name. To backup your files here's what I'd do:
1. Grab the files you want to grab.
2. Make a folder on the root of the laptop called "backup".
3. Move/Copy the files you wish to backup into this folder.
This may work because the other path would be something like
c:\Documents and Settings\username\Desktop\folder\folder2\myfile.pdf
or for Windows 7
c:\Users\username\My Music\iTunes\My Media\Music\artist\album\track1.m4a (for example...see where the issue lies?)
Thanks,
cyan990
Jun 03, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
ACER Aspire L100 Desktop is dead?
If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
Dec 08, 2009 | Acer Aspire L100 PC Desktop
I bought a sata/ide drive to usb adaptor to transfer files from my removed hard drives. The laptop hard drive connected fine and file transfer to my windows xp secondary laptop was simple and efficient. My...
i suggest trying to boot with a live linux cd, and checking to see if linux can recognize the device. that is the only thing i can think of besides double checking the jumper settings and making sure it's set to cable select. let me know if this works :) good luck
Nov 03, 2009 | Western Digital (WD1200SB) 120 GB Hard...
Cannot open files on my 150 gb transcend external hard drive
rst question whether u made shorcut backup or what ???
if not then goto transcendusa.com u may got recovery tool for data
May 31, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Need to transfer copied files to x301 after full restore
create a new folder in your hard-disk and first try to copy 1-2 files from the external hard-drive to the new folder (copy any data/work/images you have stored/created not any files of windows folder or root of c: drive)
if the above copy works then copy back all except the c: root and these folders - Windows folder, Document & settings, Program Files
May 30, 2009 | Lenovo ThinkPad X301 2776 Notebook
Cannot transfer roots web files from windows xp to routed laptop vista
Most Windows files cannot be copied and / or transferred if they are in use. The only want to actuallt copy and transfer files of that nature is to remove the hard drive and use a usb adapter to attach it to another computer and access the hard drive as if it was an external, since the hard drive is not being used to boot the system all the files will be available. Just make sure that before you do anything, go to control panel > folder options > view > click on show system files and folders. This will allow you to be able to see all files and folders regarless of what they are.
Mar 10, 2009 | Microsoft Windows Vista Ultimate Edition
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
2,636 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
