Question about Frigidaire PLHS269ZC Side by Side Refrigerator
Hello.. the compressor on my Frig is not running. when plug the power cord in, the compressor makes a little hum and then a click sound. Could this be a compressor problem or some other parts in the system? Thank you, Ken.
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerhello.. the compressor on my Frig is not running. - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 30, 2010
We just came home and found water on the floor....the freezer had melted and the frig is warm...we threw everything out....we cleaned the dust behind the frig...what do we do next?
Do you see anything happening with the refrig. is teh compressor running..do you hear any fan on?? or perhaps every couple of minutes their is humming/buzzing sound floowed by a click??
If you hear nothing at all going on i would suspect the thermostat or the defrost control board is the problem,If ya hear a buzz/click then what would be needed was the relay/overload on the compressor
Reply with what exactly your experiencing and i could help ya narrow it down
GENE
Sep 18, 2011 | Maytag MSD2756G Side by Side Refrigerator
HAS POWER , BUT SEEMS TO BE LOCKED UP. The sound that it makes is a hum and no air in or out
The electric motor may have seized up from moisture or contamination. Make sure all air has been released by opening a valve or fitting.Disconnect the compressor from its power source, (Tape the power cord plug to compressor handle for extra safety) Remove motor cover, try to rotate the motor with a screw driver using just a little pressure.If the motor has brushes, make sure they are in contact and do not need replacement. Check to see if the motor has lubrication points. If so us a little WD40 or other oil based product.Place cover back on motor. Plug unit in to power source. If the unit still 'hums' turn switch off. I believe this compressor is oil less.If so the motor and compressor may be connected as a unit.If the compressor itself is froze up you may be able to separate the two and try freeing any frozen parts, again making sure the unit is disconnected.If the compressor does not respond to the suggestions given consider replacement if out of warranty.Good luck!
Mar 05, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Refridge would cycle on, fan would come on relay would click but no compressor. relay kept clicking no compressor. I changed relay and capacitor on compressor plugged in all went well. after a few hours...
you were lucky . compressor must run with fan or it will get too hot . if comp is running to hot it will not come on and the fan will . . do you have the cardboard back on frig . this helps direct air to cool comp .. reck the wire connections . and last you may have to take a power ( amp ) reading . the compressor may be bad .. mm.. ps do not run on ext cord and make sure the power at wall plug is good power ...
Oct 07, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
WMSD2756GES Clicking, slight burnt smell, humming then repeats
Replace the overload relays down at the compressor. Easy repair and too expensive. Do this and you'll be good to go.
Feb 01, 2010 | Maytag MSD2756GES Side by Side...
Unit stopped running. T-stat just makes a clicking sound
Are you sure its the thermostat that is clicking and not the compressor. IF the click is comming from inside the frig it is the thermostat, but if its comming from the rear of the frig its the compressor.
If its the thermostat thats clicking you can unplug the frig and remove the thermostat and jump the two wires together and plug the frig back in to see of the compressor comes on. If it comes on, replace the thermostat.
If it doesn't come on check to see if you have current to the compressor. If no power to the compressor check to see of the frig is stuck in defrost. Locate the defrost timer and advance one click and observe if the frig comes on. If the frig comes on at this point replace the defrost timer.
Dec 29, 2009 | Refrigerators
Small frig stopped
are you sure the compressor is running or is it just humming trying to start then clicking out on the overload, if so you have a 50\50 shot of the relay being bad, otherwise the compressor is shot
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
2006 kenmore frig - freezer and frig are both hot
if both sides are hot it sounds as if the compressor isnt running. pull the refig away from the wall and remove the cardboard cover the compressor is the black bowling ball loking thing that you see. fell to see if it is running should have vibration and making a humming sound. if its not running listen for 3-5 minutes to see if you are hearing an intermittent humming and clicking noise. this would indicate a bad start relay for the compressor. if the compressor is running then you mostlikely have a freon problem which will require a qualified technician to repair. good luck and thanks for using fixya Peyton..
Jan 27, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Humming sound unit does not cool
sounds like abad compressor, when it heats up its overheating and shutting off,i would check if the fan behind, next tot he compressor is blowing, and the lower coils are not cloggged
Jan 25, 2009 | Frigidaire Refrigerators
My Frig is not cooling
your ptc relay on the compressor when they go out they make a clicking noise. The compressor will quit and little bit later might try to come back on and click again. You need a new ptc relay. It is on the compressor little black box just unplug your refrigerator and pull the relay off. undo the wires and get a new one. Kinda staight forward compressor has 3 prongs that the relay plugs into.
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
HNSE05SS Compact Frig
There are very few parts on this unit. UNPLUG unit jump out the 2 wires to the t-stat. plug it in, if it runs the t-stat is bad.
After that theres the overload /start component on the side of the compressor. UNPLUG remove cover look for burnt wires , wires are ok feel if the compressor is HOT to the touch. if it is it could be off on internal overload. let it sit for a while plug in and listen for a hum or click in the compressor. If there is a Hum then click your back to eather your overload /starter is bad of the Compressor is bad. If you have an amp meter you can check the compressor by clipping the meter on power wire. on the information tag that has the model and serial # there is a amp draw for Lock rotor. If the unit draws Lock Rotor amps the compressor is bad.
May 21, 2008 | Haier HSB03 Compact Refrigerator
Frigidaire PLHS269ZC Side by Side Refrigerator Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
