Question about Indesit W 123 Front Load Washer
Widl 126 ex blinking all leds and not possible to operate,i think is error on programator:how to reset the programator?
  • 139 Answers
SOURCE: indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Posted on Jan 25, 2008
kjmac
  • 97 Answers
SOURCE: widl 126
hiya
this could be down to a poor connection from one pcb to the other, best thing to do is disconnect one block at a time (make a note of where it goes) and clean the connections.
REMEMBER TO UNPLUG FIRST
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
Speed boy
  • 76 Answers
SOURCE: Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Posted on Sep 10, 2008
localwonder
  • 6784 Answers
SOURCE: My indesit widl 126 is not drying
If electric, check the following areas.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If gas, check the following areas.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective
Posted on Jul 09, 2009
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
Program stops led blink
Nov 01, 2012 | Washing Machines
Washingmachine error
Looks like some electric breakdown. Major repairs is requied; probably a new machine. It is now a case for the insurance company.
Sincerely Michael
Dec 03, 2009 | Indesit Washing Machines
I do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 28, 2009 | Washing Machines
Dec 01, 2008 | Indesit W 123 Front Load Washer
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Widl 126
hiya
hope this helps
Jul 21, 2008 | Indesit W 123 Front Load Washer
Indesit widl 126 uk
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Indesit W 123 Front Load Washer Logo
221 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
