The screen and all on the buttons are frozen, I am unable to restart the terminal as the screen is frozen and removing the battery and replacing it again doesn't solve the problem. How do I put this right?
  • thefingerpos Apr 30, 2010
    The model is an opticon H15, it does have the reset button however this too is not responding.
    Hope you can help
    Steven
    Thanks for your help. I did hold down the reset button but this still did not work for some reason however by pressing ENT and ESC at the same time and holding down had the desired effect.
    Thanks
    Steven
  • 493 Answers
Would you please write your bar code scanner's model and name.
In some bar code scanners have a reset button located to the right of the battery.
You can try to reset pressing that button if your device had it.
Waiting your comments.
Hope this helps.
Posted on Apr 30, 2010
  • Ibrahim OKTAY
    Ibrahim OKTAY Apr 30, 2010
    You should press that reset button and hold pressing at least for 10 seconds. (Do not release for a while, keep pressing the buuton)
    Did you do like that?
  • Ibrahim OKTAY
    Hi Steven,
    I thought that the reset button should work, also the key combination works perfect to do the the same reset operation.
    Congratulations and thank you.
    Good luck.
    ioktay
RCA android tablet frozen won't do anything.
Try restarting the tablet, and see if that works. If you are unable to restart it, try removing the battery if you can. If you are finally unable to do anything, take it back to the location you purchased it from and get a new one.
Sep 06, 2015 | Tablets & eReaders
How do i get my asus tablett out of frozen
Assuming the restart option isn't available after pressing and holding the start button for a few seconds; you can let the battery drain ... but it may take a few hours. (Adapter must be unplugged). Then connect the adapter and restart. Another way is to remove the battery.
After the tab restarts check if system updates are taken care of. If the problem happens because of a particular app consider to uninstall that app.
Feb 17, 2015 | ASUS MeMO Pad HD 7
How do i factory reset my tablet? It is frozen on the main screen
Press and hold the power on/off button for about 3 seconds until the option to power off or restart shows up. After restarting suggest to check for updates to your device and apps. If you are not able to restart the device with the power on/off button consider removing the battery or leaving the device on (and unplugged from the adapter) until the battery is discharged.
Feb 07, 2015 | Tablets & eReaders
HTC Wildfire touch screen frozen
You can try 2 things:
    1)Soft reset - clears memory and restarts program
    2)Hard reset - deletes all saved data and settings
    Soft reset
      -Locate reset button to right of USB port on bottom of phone
      -Press reset button with stylus
      -Wait
      Hard reset
        -Press and hold both talk and end buttons
        -Press reset button with stylus while holding talk and end buttons.
        -Release talk and end buttons and press enter
How to Troubleshoot Frozen HTC Touch
Aug 29, 2017 | iPhone Apps
Toshiba c855 frozen screen
Reset the computer by either holding down the power button till it shuts off or removing the battery manually. When it restarts, allow the computer to do a systems check to make sure the registry and files aren't corrupt.
Nov 29, 2012 | Toshiba Computers & Internet
Frozen mobile
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 31, 2012 | Sony Ericsson Xperia U Black Rubber Gel...
Prs 300 has a frozen screen will not turn off or reset or connect to computer
please look clearly there will be a reset button to restart if there is no reset button then open it with the help of secrew and cut the connection of battery and after few second reconnect the bettery to to turn on but remember the connection should be same as before the cutting mean to and - to - terminals
Sep 09, 2011 | Sony Reader Pocket PRS-300
Frozen screen
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
