Question about Sharp AQUOS LC-40C32U 32 in. LCD TV
If my Sharp Aquos 37in LC-40C37U tv needs to be reset how would I do that? Not getting any power, only a green blinking light. The power supply board checked out ok.
  • Darlene Campbell
    Darlene Campbell Apr 30, 2010
    The guy only tested the capacitors on the board. He said all the capacitors are good. If the capacitors are good can the board still be bad? It wont power up, just a green blinking light.
  • 308 Answers
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Posted on Apr 30, 2010
Testimonial: "Thank you. I will get another board."
  • Ivan Apr 30, 2010
    Yes, the board can still be bad. Voltages should be checked and they should be the correct voltages and clean (no HF ripple). If one is off, it may not power up. I had a bad power bd a week ago, also Sharp, voltage was 40v, should have been 60v, set would not power up, flashed an error code. This set was different model from yours.
2 Suggested Answers
bshldn
  • 736 Answers
SOURCE: Ok.... I got a new power supply board and the tv
The pattern of the blinking is a code. If the power light is blinking by itself once per second or thereabouts it could be loose connection to Inverters, reload firmware, Inverter Unit or LCD Panel.
Posted on May 06, 2010
Testimonial: "Thank you. I will let you know how it all works out."
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Ok.... I got a new power supply board and the tv is still doing the same thing. (Sharp Aquos 37in LC-40C37U) So if it is not the power board then what could be wrong with it. I'm getting no power and only...
May 06, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Blinking led
Free diagrams unlikely to be available take the board's out and check for blown capacitors following good antistatic procedures and decide from there
Or find a good independent repair specialist to do the work and set your self a budget
My sharp aquos stopped working with a blinking power light £2000 was the repair quote for a new board and LCD panel for a £699 TV after they tried the capacitor replacement
Jul 01, 2017 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My Sharp Aquos LCD TV LC-40C37U will not power up. The green power lamp at the bottom right is blinking. We had a power surge last night, I even measured 180V on the power outlet. Is my TV now damaged?
Good day sir/maam, chances are, yes or no, yes, the surge do has the ability to damage your TV, but no, modern TVs are autovolt (it can work from 90v-240v) so check the manual or back panel to confirm. The most deadly part of the surge is it can hit more than 500v at a split of a second, damaging your TV's switching power supply. The TV's power supply is bad. it cannot produce the proper voltage to power your TV. thats why its on standby. Bring it to your dealer for proper advice on the status of your TV.
Oct 12, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Green light blinking
These all sound classic to power supply faults. Or, there may be a board that is pulling too much current due to something that has failed, and the power supply is in the protect mode.
You have to have the service rep check the set.
Jerry G.
Apr 10, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp AQUOS LC-40C32U 32 in. LCD TV Logo
1,784 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
