Question about Coleman Electric Cooler 40 Beverage Cooler
My coleman 40 qt. powerchill keeps freezing up inside and wont cool,so i have to thaw it out for about 15 minutes
  • Mary Hansen
    Mary Hansen Oct 09, 2017
    I hope this solves my problem! I have had 3 Igloo coolers. First worked perfect. 2nd one froze up all the time. I gave it to my son for camping and bought the next bigger size. Still freezes up. Thought I might be involved, since my son has no problem from old one.I have sat all 3 in my bunk are. First one was in an older truck with its bunk heater/cooler vent on the left side. Now, heater/cooler vent right next to it. I leave A/C on in bunk while I drive because it helps keep the whole truck comfy. So, I shall change my habits and hopefully fix this! Thank you.
These cooler cool aprox 30 degrees cooler than the outside air. if you keep it near a ac vent or in direct contact with the air vent odds are you will freeze any moist air in the cooler. many ppl are saying the cooler isnt cooling. most times the exterior fan is blocked or they are riding with the windows down and the surrounding air is 80+degrees so the inside temp maybe 50 degrees.
Posted on Jul 23, 2012
  • Paul Jurrians
    Paul Jurrians May 04, 2014
    one of the problems I had with my coleman 40qt cooler was the cigerette plug spring inside. compressed crom the heatthen would lkse contact with outlet. so I removed thespring and cut a piece of copper rod the lroper lenght and add some dielectric grease inside packed in full now it doesnt get hot anymore and doesnt lose connection
    Problem Solver:
  • 9 Answers
This is normal due to humidity, It means your cooler is working well.
Posted on Jun 16, 2010
My homemaker small freezer is not freezing. It is model DD1-09. Adjusting the temperature does not make any difference it is keeping the contents cool but not freezing.
is there ice buildup inside the freezer if so you must thaw it our try using a hair dryer to make the thaw faster because ice freezover inside usually is the problem
Jan 13, 2018 | Refrigerators
I have recently bought a 40 qrt coleman eletric cooler. Has it one da y and dc plug stopped working. Replaced fuse, and checkes all volt outlets in truck as well as fuses in fuse panel they all work.
Did you accedently or spark power wires? These have a tendency to blow the diode if that happens. Also check fuse in plug of cooler. Take it apart an look sometimes the wires break.
Jan 11, 2015 | Coleman 40 Quart Powerchill...
Can i use a coleman ac adaptor model 5232f640 for charge a car battery
Isn't that the power cord for a Coleman 40 qt Powerchill Thermoelectric Cooler? Without the proper equipment, you take a chance of over-charging and blowing up your battery as it would be a direct current with nothing to regulate it and no needles to let you know how much of a charge it has.
Why not catch a ride down to AutoZone and buy a NOCO/180 mAh 12 Volt solar battery charger (that's right, solar power charger) for less than $25? It comes with 8' of cable and suction cups to mount it on the car while it charges with sun light. Neat little things for sure. I own two.
Sep 14, 2013 | Electronics - Others
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Coleman thermoelectric cooler not cooling
Sounds like the Peltier effect elements have failed.
http://www.tetech.com/Peltier-Thermoelectric-Cooler-Modules.html
Depending on your handyman skills, you can change them yourself or have someone troubleshoot and change them.
Sep 12, 2012 | Coleman 40 Quart Powerchill...
I HAVE A COLEMAL 40 QUART POWERCHILL COOLER. THE MOTOR BURNED OUT AND I CANT FIND THE RPLACEMENT PART. THE PART IN THE DIAGRAM DOESNT LOOK LKE THE 1 I NEED
Coleman 40 Quart PowerChill Thermoelectric Cooler
What diagram are you looking at? I only see one motor in the unit and it's the only one that Coleman has made for your item.
If all else fails, Coleman has a customer service line that can help, 1-800-835-3278 or you can email them at consumerservice@coleman.com
Hope this helps,
Glenn
Jun 29, 2008 | Coleman Heating & Cooling
Coleman Electric Cooler 40 Beverage Cooler Logo
1,932 people viewed this question
Top Coleman Home Experts
john h
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
