Question about Cannondale Road Mountain Bike Bicycle Aa Sticker Decal
How to replace wheel bearings on my cannondale f800 lefty jake
Replace front bearings on wheel,thanks.
5 Suggested Answers
  • 2418 Answers
SOURCE: how to remove front wheel
You will need an 8mm allen wrench or allen socket, a crank arm puller, and a bottom bracket tool. There is a cover on the left side you need to remove see picture. Once the bolt is loose. You may be able to pull the wheel with out the use of special tools. Hope this helps.mcneb_9.jpg
Posted on Jan 23, 2011
dunnbiker
  • 8546 Answers
SOURCE: how to dismantle cannondale lefty
http://www.cannondale.com/usa/usaeng/Instructions
select Lefty in the right side rolldown
Lots of manuals
Posted on Feb 27, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a 2001 model
The smaller bearing comes out the other side
http://www.eightyaid.com/fileadmin/users/000_for_all/manuals_forks/2011_Lefty_OMS.pdf
Posted on May 20, 2011
SOURCE: how to dismantle lefty
HI, Am looking for advise and hopefully a manual on the Lefty..... an old one..........
Am pensioner so funds are limited and I hoped you would be kind enough to give some guidence.
The LED on the top of the shock when the button is pressed shines RED ...........
but the shock remains locked ...........!!!!!!!
Please let me know what I can do to get it to move out of the locked position ?
Is it possible that the valve is stuck ??
Do hope you see the way to give me a little guidance.
Thanks Willy Willox
Posted on Jun 15, 2013
How do I fix an oil leak on my cannondale lefty
First try to replace the oil and replace the oil seals then inspect the tubes for scratching/gouging while you have them apart.
Sep 25, 2014 | Cannondale Lefty Alloy Dlr Mountain Bike...
Lefty shock axel bolt removal
I would need more information, but it sounds like that the bolt is most likely stripped and in need of replacement. Your local Cannondale dealer should be able to get one of those for you.
Mar 18, 2013 | Cannondale Jekyll 1000
Shipping a bike. dismantling instructions; front fork in particular
Since there are a lot of varieties of the Lefty go here and search the list for "LEFTY".
http://www.cannondale.com/manuals
Or you might just get away with deflating the pressure preload and collapsing the fork.
Jul 02, 2011 | Cannondale Lefty Alloy Dlr Mountain Bike...
I have a bicycle (Cannondale Bad Boy SOLO Ultra 2009 white edition) and I can't find a front mudguard that will fit the front lefty soli fork setup. Any suggestions?
I have a set of SKS X3's for my Jekyll with a Lefty. The front has a special large insert for the headshock-sized opening at the bottom of the steerer tube. Maybe check with a Cannondale-shop to find one.
Here's another solution at the bottom...
http://www.bikeforums.net/archive/index.php/t-277507.html
Mar 27, 2011 | Cycling
Will the cannondale xc3 mtb stem fit on my lefty headshock? And how do I do it?
the XC3 stem comes in a 1.5 in clamp designed to fit on cannondale headshox systems. The lefty fork you have may or may not be compatible, you would have to check your fork to see if it is the right size.
There is an XC3 SL conversion kit for lefty forks that are not the same size and includes the stem and steerer replacement.
Swapping stems is quite easy on the cannondale. Loosen the two bolts holding the stem to the steerer and undo the bolts holding the handlebars, remove stem and replace.
If none of this makes sense then I would strongly urge you too take the bike into your local bike shop, preferrably a cannondale dealer, and have them show you. It will take only a couple minutes and they can confirm compatibility.
Jan 06, 2011 | Cycling
How to dismantle lefty
Hi!
The Cannondale Lefty fork can only be disassembled with speciality tools. You can read illustrated instructions here: http://www.gordlaw.com/index.php?Cycling:Cannondale_Lefty_DLR
Please check that your Lefty fork is identical to the one described, as the process and tools are different for the various Lefty editions.
As a warning, dismantling the fork could lead to serious injury if you don't know what you are doing. Please read through and understand all instructions before deciding whether to do it or not. Good luck.
Apr 04, 2010 | Cannondale Road Mountain Bike Bicycle U...
Cannondale Road Mountain Bike Bicycle Aa Sticker Decal Logo
538 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
