Question about Acer Aspire 4720 Notebook
Other device is not instal - Acer Aspire 4720 Notebook
  • A Miller May 11, 2010
    Im sorry ... more information needed if you expect an answer from this site. .......
    Sergeant:
  • 279 Answers
Under device manager check the device that is missing: i.e Bluetooth, Sound Device, Multi card reader, WIFI, Display adapter, Infra Red, LAN, Modem etc, switch it on (for bluetooth).
Posted on Apr 30, 2010
Wecom h580 driver
Try going to ASUS web site and reinstall the correct drive for your unit.
If you check your device manager for flags or errors, you may find either the driver for your device is not installed or installed with flags or errors.
Disconnect all USB devices from ports and reboot unit.
check your device manager and remove any flagged devices.
Reboot again and install your device ( Wecom h580 )
Windows should see the device and attempt to install the correct driver.
Also, being this is a wireless headset, you may need to reset the device.
Hope this helps
Apr 03, 2014 | ASUS Eee Computers & Internet
How to transfer applications installed in my device to my media card?
  1. Connect your device to your computer
  2. Run the installation program from your computer. The installation program will prompt you to install the software application to your device using ActiveSync or Windows Mobile Device Center.
  3. Select whether to install the software to the device memory or to your memory card
Feb 21, 2012 | RIM BlackBerry Storm 9530 Smartphone
I want to install my new samsung usb driver, how can i possible do that??
USB devices are made to be conveniently installed or removed while the computer is running. With their small size and fairly large capacity compared to a floppy diskette, USB devices also allow the means to transport many files in a pocket. Most USB devices have a common interface, allowing them to be used on almost any computer.
Instructions to install one are as below :)
  1. Step 1 Open the package and remove the device.
  2. Step 2 Connect the device to an available USB port. Devices are made to connect only one way. Ensure that the device is properly positioned before inserting. If there is more than a slight resistance, remove and check the position again.
  3. Step 3 Install the device driver if one came with the USB device. Windows should find the device and either install a driver or ask for driver media. Once the device has been installed, a new drive letter will be assigned to it.
  4. Step 4 Remove the installation CD or other installation media.
  5. Step 5 Restart the computer to ensure smooth operation.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • Forcing the device into the port the wrong way will cause a malfunction that might result in the device and/or the port having to be replaced.
  • After installation, the USB device can be used as a portable storage area that can be moved from computer to computer. This alleviates the necessity of burning a file to CD or DVD for transport.
Hope it helps .. if yes please rate me on Fixya.
Jul 28, 2010 | Computers & Internet
I installed incorrectly .. plugged intojump drive before I put the CD. how do I get it to work now?
In windows XP, you need to open the Device Manager.
With Device Manager open, plug in the USB device. Find the driver for the USB device It will come and go as you plug and unplug the device if you have the right one). With the USB device plugged in, right click the device and select 'uninstall'.
After the driver is gone, unplug the device.
Close everything, remove the USB device.
Now install the 'Install disk' and run it. Don't plug in the USb device until the install program asks for it.
Apr 16, 2010 | Motic DS300 Monocular Microscope
Purchased EasyCap video capture device to transfer DV from Digital Video Camera to Computer, have installed Driver receive with devise and shows as Smart Video Capture on desktop. when I attach device and...
it seems that you havent followed the installation procedure correctly. most of the devices comes with written installation directions.
now uninstall the drivers form your computer, disconnect the device from the computer and reboot the computer. then install the driver of the device first(at this point dont attach the device to the computer) after installing the driver than attach the device to the computer. the operation system will automatically detects the device and install it, or if you've asked for the driver click the automatic dectect and install button.
Mar 24, 2010 | Computers & Internet
The drivers for this device are not installed. (Code 28)What do I do now
First of all I would like to know what device you have that cannot be installed to better understand how to slove your problem, however your most likely problem is related to your device driver, download an updated version and reinstall.
Also find this link for explanation of Code 28.
http://support.microsoft.com/kb/310123
Keep Moving Foward.
Jul 18, 2009 | Microsoft Computers & Internet
Installing usb cable without cd
you can not install the cable it is the device atteched with the cable that gets installed.to install a usb device with out cd insert cable into device and then the computer.you should see a small window that says :new device found: then installing device then:
installation failed no drivers found etc...now at this point you tell the computer to search online for appropriate drivers. if this doesnt't work write me and tell me what the device is and i'll help you find appropriate drivers
Apr 23, 2009 | Computers & Internet
Trying to install external DVD and it won't load! Why? I get a yellow flag in device manager!
Often you should install the drivers (using device CD), before you connect the external device to your computer.
1) Delete the driver from device manager,
2) disconnect the drive from computer,
3) restart computer,
4) install the driver (using device CD),
5) after driver is successfuly installed,
6) connect the external device.
Nov 30, 2008 | Lite On Computers & Internet
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
Acer Aspire 4720 Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
