Question about GE APH10AA Air Conditioner
I have Fiait Uno. I have peculiear problem. Ac gas reduces in 3-4 months. But when checked there is no leakage. What I should do?
  • Brian Niten May 11, 2010
    If the unit is losing refrigerant then the only place it can go is a leak. They just haven't found it.
  • GE Master
  • 1,147 Answers
The freon system is a sealed system. If the "Gas" keeps depleating, there has to be a leak. no question. If a tech is searching for a leak, request that he use dye in the system. This will show any leak in the system.
Posted on May 02, 2010
ELECTRICAL ISSUE IN SUBURBAN
if the bridge (three diode that turn AC current to DC in alternator) is bad it causes internal draw
Jun 19, 2014 | Chevrolet Blazer Cars & Trucks
Automobile noise, emissions exceed the standard
May be due to the engine exhaust gas in the high temperature oxidation, resulting in leakage of exhaust system. use obd2 inspection of the exhaust system at the interface of it is gas corrosion, interface pad has not been washed. If the exhaust system leakage should be timely to the 4S shop for repair or replacement of leakage components, reduce the pollution emission of harmful substances in environment.
Dec 07, 2013 | Toyota Cars & Trucks
The compressor is running but no cold air
Hello there, when the compressor works fine and everything works just fine then the problem is the gas which is inside the compressor. The gas is often referred to as refrigerant and differs from unit to unit after extensive use the refrigerant reduces and with time the unit stops cooling. Although the refrigerant levels could have dropped due to a leakage in the pipe system. Simply get an expert to determine the kind of gas and get the compressor refilled this should sort the problem out also get the expert to check if there are any leakages and get them plugged.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 02, 2011 | Refrigerators
I found some oil linkages around the fuel pump is that from the pump its self or gasket
Usually observing the dripped fluid on the ground as first encounter to acquire if is gasoline leak or oil leakage. A gasoline leakage should have been caused due to overpump at the gas station. Second, a leak from the engine if is antifreeze overflow because of over filling the hydrant with water causes overflow when AC is turned on for the first time. Third, the engine oil would dispense when too much was put in container. The reason is as vehicle precaustion, else the car would not start due to too much oil lubricant. Perform a vehicles fliud levels inpsection to acquire if any require refill due to the leakage. Alternatively, if any requires reducing for example, a mechanic would determine how to dispense the old fliuds in replacement of new oils. The vehicle should perform better. Usually changing fliuds causes efffecient engine performance,least heating, AC cooling capacity, and least polutant generation like air or gasoline leakages.
Jan 13, 2011 | 1984 Toyota Corolla
My toyota altis 2002 1.6E is using up oil, almost every month we need to put a liter of oil. what could possibly cause it?
if this car has more than 100,000 miles, try switching the motor oil to a "high mileage" formula oil. this can reduce oil leakage, and reduce oil burnoff.
Nov 06, 2010 | 2004 Toyota Corolla
My air is not running correct.. blowing hot air out.. what can we do to fix this problem
hi
this may be because following reasons.
1. you might have kept the temperature selection switch in heater please check it.
2.there may be leak in the AC line which might have drained the refrigirant so no cooling effect.check the line for leakage.
3.the refrigirant used may be less which doesnt give much cooling effect.
4.the cooling fan which cools the refrigirant may not working or speed is reduced which may reduces the heat transfer rate
if my answer were useful to you please vote me.
Jul 11, 2010 | 2003 Hyundai Santa Fe
E4 Error in Hunday Split Ac
where are you located , like if your residing in noida UP then u would face the issue due to polluted air , and the dirty and harzadeous gasses comming out from back water river, next time when technicians come , kindly ask them for proper flushing and testing it by nitrogen pressure. there can be a minute leakgae.
Mar 19, 2010 | Heating & Cooling
GE APH10AA Air Conditioner Logo
42 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
