Question about RCA TruFlat 27F520T 27" TV
My RCA TruFlat TV turns off by itself
My RCA TruFlat TV isnt that old. Ive only had it for about 3 years and it shuts itself off!. I cleaned it, had my Dad take off the cover and look at it to see if it was dusty. Not a dust speckale. This is VERY annoying. I need help.
5 Suggested Answers
  • 48 Answers
SOURCE: rca 14" truflat
really depends on the model. I've got a 2005 26" RCA truflat that has both digital and analog ota tuners--I can pick up off of rabbit ears OTA broadcasts, as well as via coax cable (cox cable) any of the unencrypted clear digital channels (QAM). Just can't handle the encrypted channels. If there are multiple coax inputs, check their labels--if labeled digital, likely that you've got a QAM digital tuner. Also, in the menuing system, channel scan--does it identify signal type as selectable digital/analog?
The surefire, get the model number, goto RCA.com website, download the user manual.
Posted on Mar 14, 2009
  • 13 Answers
SOURCE: RCA Truflat 20F512T turns itself off and on
If it is an intermittent problem, changing the tact switches on the main board solves a lot of these problems. Tact switches are on front of main chassis where customer controls activate them.
Posted on Oct 24, 2009
honeymokey
  • 3113 Answers
SOURCE: my rca truflat tv's volume
It is probably the volume button.I clipped two prongs on mine and use the remote to turn it up and down
Posted on Jan 23, 2011
honeymokey
  • 3113 Answers
SOURCE: My RCA TruFlat 27F520T 27" TV started acting up.
The buttons on the tv are the problem. I clipped the prongs on one of mine and fixed it .Just use the remote now
Posted on Jan 28, 2011
Keeps turning off
some tvs like the one i used to have did th same thing. turned out the remote eye on front of set needed cleaned. worked fine afterwards. also remote buttons are bad about getting stuck you might try cleaning it by taking it apart cleaning it with alcohol. hop this helps
Sep 30, 2013 | RCA TruFlat 27F520T 27" TV
I have a 20'' RCA TruFlat SDTV/DVD combo that's not even 2 years old and for the last week or so, whenever I try to turn it on, the picture flickers for a second and then shuts off. It usually takes 3-4-5...
The RCA tv's have the highest breakdown problems in the industry and usually take a slew of parts in the process when they finally quit. Now if you are very lucky you may have bad connections on the main board, but with history these sets carry I'am inclined to run it until it fails completely and buy a new tv.
Jan 02, 2011 | RCA 20F610TD TruFlat TV/DVD
My RCA truflat tv won't turn on? It is only like
Could be a fuse in the unit or a bad powersupply i would have a estimate done on it before repair gets started as a newer tv would cost less if this was a major issue.
1. check fuse
2. check power supply unit
If you do not know how to do this would recommend you take it to the experts as there is serious high voltage that can be fatal inside, Please do leave postive feedback and ratings for your free answer today.
Oct 24, 2009 | RCA TruFlat 27F520T 27" TV
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
TV only 2 months old ceases to work
Hi
I think it is the EHT for some reason it blew off for you. You got a miniature picture after you turned it on again because it was partially damaged and then it blew off completely. It can be fixed from a competent person.
Regards
Jan 07, 2009 | RCA TruFlat 27F520T 27" TV
RCA TruFlat TV
You may have a loose solder connection on the circuit board inside your set.
You need to have a technician check it for you.
Stargazer
Jan 16, 2008 | RCA 27F530T 27" TV
Turns off by itself
Ours did that too after 2 years of faithful service. We got a quote for repairs equaling around $200 USD when the tv only cost a little over $100. You can price-check to see how much repairs are for places, however, it was just best for us based on retail price paid to get a new one. ... and sometime we shall get one!
Oct 04, 2007 | RCA TruFlat 27F520T 27" TV
Help
It's probably something wrong inside, so if you don't want to open it you will probably have to send it in for repair. Since it's only two years old, might you still have waranty on it? Try to contact the dealer to find out. If not, I fixed a similar problem on my Sony TV by opening it up, and adjusting the knobs inside. I adjusted *one at the time*, and returned it to its starting position if it didn't seem to have any effect. I finally found one that caused my TV to stay on. If you open it, be very carefull. There are components that can shock you *even if the TV is off and disconnected!* So don't touch any metal with your fingers. While you're in there, clean out any dust to reduce risk of fire later.
Sep 03, 2007 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
94 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
