Question about HP w1907 LCD Monitor
HP w1907 LCD Monitor blacks out after 1 minute
Lights up again if push the on/off switch on top of screen, then will last another minute before blacking out again.
    Sergeant:
  • 244 Answers
Check your monitor cable, try to reseat it (VGA / DVi port) at the back of the computer. If it still does turn off try to reseat the graphics card (if you have an expansion card) If reseating wont fix it, try this monitor to another computer and see if it still turns off. if not, then it is a problem on the video card of your computer, if yes it means your monitor is faulty.
Hope this helps.
Posted on Apr 30, 2010
My monitor occasionally blacks out. I turn just the monitor on -- wait a few minutes then it works ok for a while until it blacks out again
There are controls that turn off the monitor, both in Windows control panel and the monitor itself. The system should know if activity is happening, and should not blank if active.
Look at screen savers, too.
Jan 28, 2011 | HP w1907 LCD Monitor
HP monitor w1907 lcd switches off to standby.
your hp monitor has an electronic component problem inside, probably some busted capacitors or ccfl lamps that failed to light...best is to bring the unit to a qualified LCD repair center near you..
May 09, 2010 | HP w1907 LCD Monitor
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
Hi
Please try this monitor in another PC
If it fails then the monitor is faulty as it seems to be heating up and then cutting out
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | HP w1907 LCD Monitor
HP Monitor w1907 problem
First place to check will be the power supply section, look for bad caps with bulging top or bottom seal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Monitor will not switch on
your monitor could possibly have a backlight problem.. the wires to the lights are known to come off the lights in the screen.. if you try to check it your self be careful the lcd screen and lights are very frigile, nad can brake easly..
Oct 08, 2009 | HP w1907 LCD Monitor
HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
Jan 30, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
613 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
