Question about Brother Disney PE-180D Computerized Sewing Machine
Stitching trouble Can anyone help !! been having this trouble for a while now with my brother 180d as the bottom cotton from the bobbin is showing through the top rather than the coloured top cotton, not sure if i'm doing anything wrong ? can anyone help??
    Genius:
  • 1,116 Answers
Here is a trouble shooting chart - http://www.emblibrary.com/EL/elprojects/SimpleProduct_ELP.aspx?CS_ProductID=PR1238&CS_Catalog=Elprojects
I would start with cleaning (see maintenance section of the user's manual).
This has to be done more often with sewing/embroidery machines that have a drop-in bobbin.
Be sure to use bobbin thread for machine embroidery.
Always thread the machine with the presser foot up. This will insure the thread is seating into the tension control.
Posted on Apr 30, 2010
Thread is bunching up in bottom.
It sounds like you have no tension on the bottom bobbin reel. Did you check your tension on the bobbin reel. The tension must be right on both sides. When pulling on the cotton when the reel is in its bobbin case you need to feel a little resistance. Adjust the tiny srew on the bobbin case to tighten the reel to avoid it to turn in the casing.
Jan 11, 2014 | Brother PE770 Computerized Sewing Machine
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
Hi, I have been using a zig zag stitch on cotton, but recently the stitch has appeared on the wrong side of the fabric - that is the side that I am looking at shows the back of the stitch, and the...
Sounds like the bobbin case tension is not properly adjusted. Try turnibg the adjusting screw about 1/2 to a full turn clockwise and see if it is better.
Jun 13, 2010 | Brother XL-5700 Mechanical Sewing Machine
I need to oil my own machine, Brother Innovis 1500, I bought it in the US and brought it home to Saudi Arabia. The machine began acting up now and I'm trying to find info for oiling it. The under bobbin...
No oiling a computorized sewing machine. These areas are factory sealed and only serviced by a Brother tech.
Refer to the care and maintenance section of the manual for cleaning as this needs to be done more often with sewing/embroidery machines that have the drop-in bobbin.
Look for thread snips and lint.
Raise the needle to it's highest position before removing and replacing the bobbin case.
You can get a manual, if needed at the Brother website to view or download at no cost.
Eventually you will have to take the machine in for service. The site has a dealer locator, if needed.
Apr 29, 2010 | Brother Disney PE-180D Computerized Sewing...
SETTING THE TIMING ON DISNEY BROTHER PE-180D EMBROIDERY MACHINE
Email me for attachment of instructions drivewithken@blueyonder.co.uk
Mar 05, 2010 | Brother Disney PE-180D Computerized Sewing...
Brother Disney PE-180D Computerized Sewing Machine Logo
257 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
