Question about AB Soft Computers & Internet
I want to access software form server machine and that only install server machine how can i access that software without my machine
Files and directory listings on a Web Server
Without knowing what software you are using its hard to give specifics but it sounds like you need to change the permissions on the folder. You may have the "read" attribute set but not the "list" attribute, you can open the file if you know its name but not list the contents of the directory. Unfortunatley these permissions must be set from the server side.
May 10, 2010 | Computers & Internet
Window vista and kaspersky anti-virus will not let me log onto my company e-mail which is threw a microsoft exchange sever
You can check if it is the antivirus (AV) software simply by right clicking on the kaspersky icon (bottom left of your screen) and closing the application down temporarily, then try connecting to your exchange server. If you can now connect (without the AV software running), your problem is just with the setup of the AV software. You may previously have responded wrongly to a security request question and often the quickest route is just to uninstall and re-install the AV software if you don't know how to rectify this. If you still can't connect without the AV software loaded the AV software probably is not your problem so re-load it then speak with your IT guys at work to set your machine up correctly for access.
Feb 14, 2010 | Microsoft Windows Vista Ultimate Edition
Can't access D-link DP 301U using IP address 192.168.0.52 with subnet mask 255.255.255.0
try to install ps admin software youres machine connect device your devices console port try it ?
Jun 09, 2009 | D-Link DP-300U (DHDP300U) Print Server
I have a website already set up. I need to update the website and change an old form to a new one. When someone goes onto the website I want them to have access to the form to view and print it. I want the...
I'm with you until you said 'available in Word'. To update a form on a website just upload a new HTML page to the web server.
to view and print they should be able to use the browser commands (and in Windows with IE they should be able to export to Word if they have Word installed on their PC).
Can you give more detail is this is not enough of an answer?
Dec 08, 2008 | Microsoft FrontPage 2003
Printing custom forms from MYOB
Try to Copy and paste your forms into the myob 12.5 forms folder.
and also try to copy and paste this form into your customer cards for your preference of form to be used for that customer and see if it works. it should show up in the customized forms list now!
I Hope this helps!.
Sep 22, 2008 | Myob Accounting Plus (BPJUBC00) for PC,...
SQL 401: cannot open database
SQL database Recovery Software remove errors from SQL server database and allow recover your all database of SQL Server 2012 or below versions. The software support with all over version of SQL server. Try at here:-
SQL Database Recovery
Jun 06, 2008 | Computers & Internet
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
May 29, 2008 | Microsoft Windows Server Standard 2003 for...
Access problem
see if the LDB file still exist and delete it...
Whenever you open an Access database, a file with the same name as the database and an extension of LDB will be opened automatically. For example if you open Northwind.mdb in the samples directory of your Access/Office installation, a file called Northwind.ldb will be generated. This new file keeps track of users and the objects that require some form of locking in the database. When all users have exited gracefully from the database, the LDB file is closed down and deleted.
thanks for rating
Jan 09, 2008 | Microsoft Office Access 2003 (077-02871)...
Quickbooks point of sale 7 database connection from client to server.
Might be a silly question, but - do you have Access installed on both machines? If you have moved the access file to your networking file, you'll need the main program on the machine you are trying to access it FROM as well...
Dec 20, 2007 | Computers & Internet
Connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Sep 26, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
20 people viewed this question
Top AB Soft Computers & Internet Experts
David Payne
David Payne
Are you an AB Soft Computer and Internet Expert? Answer questions, earn points and help others
