Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
How to tell your net gear router is no longer working correctly It connects to the internet throuigh the modem I am plugged into port # 4 and I have tried port # 1. At any given time I loose connection and all the lights on the router are lit. I have replaced the modem could the router being going bad. I have to disconnect the modem and the router to reconnect it may stay connected for 1 hr or 3 but then disconnects again. It is about 4 or 5 years old.
    Sergeant:
    Novelist:
  • 172 Answers
HI jamesbigble. To see if I understood your problem correctly. You are using a computer thru a router. And the router is connected to a modem. After a while all the lights on the router are lit. And then you have to unplug it and plug it in again and it will work for a while right? Well, if that's the case, that's the router for sure, you need to replace it. If you see something like that happening to the modem, well the same answer for the modem. If any modem, router or switch have all the lights lit, it means some serious problem. Maybe hardware/power or firmware issue. In case you dont want to spend money, I would recommend go to the netgear website and download the latest firmware for your router and try it. I hope this helps. Please dont forget to rate and write positive feedback for our fast-free support today. Thank you :D
Posted on Apr 30, 2010
Tip
No internet connection tips
I listed some of the things you should check if the internet on your desktop or laptop is not working.
Computer connected to the modem
1. Check the cables if its properly connected to the modem
2. check the lights on the modem, if they are all ok.
3. Check if the modem is set on standby mode. MOdem should not be on standby.
4.Power cycle your modem. power off your modem for 3mins, and then turn it on. Wait for the lights to get steady and then check your computer if it has internet access.
5. Call your Internet service provider , it can be a problem with their line.
Computer connecting thru the router
1. If its wired check cables.
Some user plug the computers to the INTERNET or WAN port. Computers should be on the LAN port . Modem should be plug into the WAN or internet port.
2. Check the lights where you connected the computer. See if the port light is lit up
3. Check your computers ip address. HOw?
If your using windows
Click start - run - cmd - enter ipconfig - look for ip address.
If the ip address is 169.xxx , this is an invalid ip.
If your using mac
Click apple icon
Click on system preferences
Go to network and then look for tcp ip address
If you get an invalid ip address the solution is either you need to plug the computer to another ethernet port or your router needs to be reset.
If its wireless and your getting 169.xxx
Theres a possibility that the wireless security on your router and your laptop dont match. Check your wireless security and make sure you enter it correctly.
4. Your router might not be communicating well with the modem. YOu can do the steps above to check if the modem is working properly.
5. if the modem is working. That only means you need to setup your router again to the internet. You can do it using the setup cd that came with your product or you can do it manually by calling your router tech support.
on Jul 08, 2010 | Computers & Internet
My computer connects to my wireless router, but I cannot get on the internet. The "Locked" light is on - I'm not sure if this is the problem .
Thank you for contacting the experts. The first thing to do is to ensure that your router is getting internet connection.
1. Plug the ethernet cord from your modem to your laptop directly by bypassing the router to see if you can get on the internet.
2. If you are able to successfully get on the internet, then plug the cord from the modem back into the correct port on the router. Make sure you have the cord plugged into the port that says "internet".
3. Once that is plugged in correctly, depending on if you are using DSL (phone company), you will need to log into the router to change the password/user ID settings. If you are using high speed (cable company), then you will not need to put in a user id/password unless you are setting up security.
4. Power cycle your router and modem simulatneously to make sure that the router picks up the modem connection and the modem picks up the router.
I hope this was helpful and thank you for contacting the experts.
Jan 29, 2010 | Belkin (F5D7230-4) Router (587009)
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
Configure Router
Make sure that the modem is connected to the internet port of the router and computers to munbered ethernet ports.open 192.168.1.1 in your internet explorer page.It will ask for username and password.Leave the username blank and in password type admin.You will get the linksys page.In the blue bar click on MAC address clone.Enable the MAC address clone service and click on clone.Now scroll down and click on save settings.Make sure that all these settings are done from the computer which is able to go online.Now power off your router and modem.Now power up modem first and then your router.Now you will be abvle to go online from all the computers.
Jan 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Netgear614 to compac pc laptop
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Wireless router WRT54G version 2
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
let me no know in case if you have any problems ...
Nov 18, 2007 | Computers & Internet
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
154 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
