Question about RCA Televison & Video
Its one of the first I think when I got it i was told if just hit on alittle it would work and sure enough it start to work just need some fine tuning but had this person here that before I could stop her she says lets make sure it really work she hits it real hard and the picture went away it styll gets power but I can't get a picture
  • RCA Master
  • 19,396 Answers
Hi.
If you could get the TV working by wacking the chassis, that means that the problem is caused by a broken contact.
Wacking the chassis is in fact a testing method that technicians used to find out if the fault was a broken contact. Today this practice is not widely used,because, like in your case, there is risk to cause more damage to the TV.
If you get no picture at all on a rear projection, then first parts to test are the ballast board, the AV input. Test also removing and putting back the lamp. Whacking may have caused lamp displacement.
A thorough testing must be done by a technician by looking for broken contacts.
Broken contacts will not manifest in the form of an hanging wire, but they will be broken solder joints in the printed circuit board. This faults cannot be detected simply observing the circuit. The tecnician must use a multimeter set to read impedance to check if there is conductivity between two contacts, doing this on hundreds of points, until the problem is detected.
I suggest calling the manufacturer at the number listed on the TV user manual, and asking a quote on repair.
If the quote is not affordable or not worth, start testing the lamp, by removing it and putting it back in place. Detailed procedure is illustrated on the owners manual.
If that does not fix the problem, find a reliable local technician. The repair will not be difficult.
Regards.
Posted on Apr 30, 2010
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
I have a 93 taurus sho. it was running fine and now it won't start. any advice would help, also need to find where i can get a owners manual so i know what fuses go where on the fuse box.
try hitting the gas tank with a piece of wood,the fuel pump may have started going bad and by hitting it loosens up the pump so it might work a little enough to start it.Then you will know if thats the problem for sure.I had this problem on a friends 1991 SHO
Feb 22, 2010 | 1993 Ford Taurus
I started my truck and the clutch was alittle tight (I almost stalled it). When I came to a red light and tried to put the truck in first gear to take off it refused to go into gear. After repreatedly...
I think your clutch may need adjusting - it sounds like its not completely disengaging when you depress the pedal all the way.
Adjust it out slightly so that it disengages fully and you should be fine.
Hope this helps, Sherwin
Dec 29, 2009 | 2004 Ford F150
Think I need a new thermostat
need to check the fan and make sure it is coming on when it gets alittle hot.
Jun 22, 2009 | 2003 Mazda Protege
Starter motor dead...I think
If Its A Manual Can It Be Kick Started? If The Dash Lights Are coming On And Dont Dim When Fully Charged Its Probably The Starter Sticking . If You Hook It Up To Someone For A Jump Start Does It Start? If No Its Your Starter.
Next Time It Wont Start Try Hitting The Starter With A Hammer.
If That Works Its The Starter.
Lots Of Things To Narrow It Down And Be %100 Sure Its The Starter
Jan 12, 2009 | 1992 Toyota Corolla
No sound
sounds like the built in sound ic took a dump and forgot to tell ya about it. It sounds like im a bearer of bad news as Im thinking its time to bury the thing and buy a new one??
Apr 08, 2006 | Emerson PD6537PL Cassette/CD Boombox
Televison & Video Logo
20 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
