Question about Epson Stylus CX6000 All-In-One InkJet Printer
I have an Epson Stylus SX600FW I'm trying to print on Vellum but the paper just go through the printer.
Use some double sided tape on the edge of the paper it will then grip to that and print the rest of the page you have to trim the end off but its the only way I could get mine to print on velum
Posted on Nov 24, 2010
Epson sx215 wont print pdf files
You need to clean the print heads first - if they are blocked they won't print.
Clean them several times - then try the print check.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
Sep 20, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
I cant print on white vellum paper on my epson stylus nx420 i need to print some invitations and it is just folding my paper
Try placing some standard paper behind the vellum paper, it might assist in holding correctly while printing.
Being so thin the paper I would guess is folding up under the print head? if so look through all the printer properties, under the maintenance section there may be a "set Plattern Gap" (set to wide) or "Thick Paper Setting"
Selecting these raises the print head up to allow for thicker paper to pass through, but can also help thinner paper from folding up under the heads.
I hope one of these works for you.
Regards GM
Apr 12, 2011 | Epson Stylus NX400 InkJet Printer
I am trying to print on vellum paper and my printer will not recognize it. I tried opening up the control panel on my computer and vellum/lightweight/film/transparent are all not options for paper types. ...
The printer has no ability to know the paper type, this setting happens in SOFTWARE, like Word. Then the command is sent to the printer, more commonly you would change papertype for photo printing....Look in the software, and not the printer itself.
Mar 18, 2011 | Epson Stylus NX400 InkJet Printer
My epson sx600fw prints ,after that it then comes up with paper jam any one know how to sort the fault
Go To Below official Epson Printer Page For Your problem, Epson Stylus NX420 All in One Printer
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Nov 28, 2010 | Epson Office Equipment & Supplies
Why won't my printer print on vellum paper? Im trying to make baby shower invites and the paper just comes right out.
Im guessing ...
I had a similar experience with a different brand ...
Your printer thinks it grabbed two sheets of paper.
Open your priter program (in the control panel) and see if there is a setting for Vellum
I hope this works for you
a
Oct 13, 2009 | Epson Stylus NX400 InkJet Printer
I can't get my Epson Nx400 all in one to print on vellum. It just spits the paper through...Help!
I had this same issue and I got the printer to print on vellum but I can't say it looked all that great. But here's what I did. I went into the printing preferences and then to the maintenance tab. On the maintenance tab you'll see an option for Printer and option information. Click on that and then you will see a little check box down at the bottom of the pop up and it says Thick paper and envelopes. Put a check in the box. Click ok and then it should print on the vellum for you. Make sure you put the vellum in the printer the right side up (front side) because if you don't it will print all messed up.
Jun 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
350 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
