Question about Alpine MRV-F407 Car Audio Amplifier
I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
    Scholar:
  • 111 Answers
RMS Continuous Power (at 12.0V)
Per channel into 4 ohms...............40W, 0.08% THD
Per channel into 2 ohms ..............50W, 0.3% THD
Bridged into 4 ohms.....................100W, 0.3% THD
RMS Continuous Power (at 14.4V)
Per channel into 4 ohms...............60W, 0.08% THD
Per channel into 2 ohms...............80W, 0.3% THD
Bridged into 4 ohms.....................160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 Ohms..............120W
Bridged into 4 Ohms....................320W
This should help.
Posted on Apr 30, 2010
I have an alpine mrv-f307 4/3/2 channel. I have it hooked up to 2 12in Kenwood subs. Right now standard 2 channel each sub having their own. I heard doing a series hook up and bridging the subs to the amp ...
Bridging an amplifier refers to combining the power of two channels to run one speaker at higher power. If it is wired correctly, your amplifier is running with 4 channels bridged into 2 speakers now.
Mar 11, 2015 | Kenwood Car Audio & Video
Just want to know what speaker wattage matches my v12 mrv f705 85 rms x4 channel amplifier?
Use speakers that will handle 85 RMS continuous or higher wattage. I have 200 watt Rockford 6.5s on a 75 watt amp. They sound great with plenty of headroom if I go to a bigger amp.
Nov 20, 2012 | Alpine Car Audio & Video
How do I bridge this amp to run a single sub?
  • To bridge 1 sub with a Alpine MRV-100M amp you run the negative and positive wires coming from the speaker to the outside terminals on the AMP respectively.
Regards, Tony
May 22, 2011 | Alpine MRV-100M Car Audio Amplifier
I obtain recently a car amplifier model: mrv-f400 of alpine, i want information about the correct way to instal thanks
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=MRV-F407
THE ABOVE LINK WILL DOWNLOAD A MANUAL FOR THE SIMILAR MRV-F407 AMPLIFIER. IF YOU WANT TO PURCHASE THE EXACT MANUAL, YOU CAN OBTAIN IT FROM PACIFIC COAST PARTS AT 800-421-5080 PART NUMBER=68P50958W56. IT IS AROUND $5.00 PLUS SHIPPING. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 24, 2009 | Alpine MRV-F540 Car Audio Amplifier
How 2 bridage an alpine n a kenwood togethes
you cannot bridge them together. if they are bridgeable, you can bridge one amp to one speaker and the other amp to the other speaker. make sure not to go lower than the required ohm for each amp. also, you probably will get a different output wattage for each amp.
Nov 02, 2009 | Car Audio & Video
Hi i was just wondering if anyone could tell me what the max wattage is ?????
Hiya 50W RMS into 4 ohm per channel (X4) or 70Watt RMS into 2 ohm. The peak rating i think is about 150W
Jul 11, 2009 | Alpine MRV-F540 Car Audio Amplifier
Over heating problem
"how do i made amp ohm instead of 4"
What?
I think you're asking how to make the amp 2 ohm. If your 12's are already wired for 2 ohm, just connect the 2 leads to the bridged terminals on the amp. There will be 4 connections on the amp. One for each channel. Usually, the two outside terminals (one positive and one negative) are the bridge and it'll be noted with a line painted on the surface above the terminals. That's all you have to do.
If it is overheating, you should put cooling fans on it.
Aug 31, 2008 | Alpine MRV-T707 Car Audio Amplifier
Need to know how to wire Alpine 12" 1242D 4ohm Want to use 1 speaker in ported box with Phoenix gold 2200pro amp
As long as the total wattage of the amp does not exceed the total wattage of the speaker, you can bridge the amp. To do this, put the positive wire of the speaker on the positive terminal of channel 1 on the amp, and the speaker negative wire on the negative terminal of channel 2. This allows you to run the amp's full power into one speaker.
Aug 02, 2008 | Alpine Car Audio & Video
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
Need a part for my alpine mrv-f407 amp
as far as i know, nobody stocks or sells replacement cases for this amplifier, your best bet would be to search for a good dead one on ebay or somewhere similar... failing that, you can take the case apart and use an aluminum or metal paint to repaint it after sanding it. the reason for using a metal paint is that most regular paints will have an unwanted insulating effect and not allow the case to perform its intended purpose, giant heatsink. you can also try to use metal polishes or an extremely fine grit sand paper (1000-2000 grit) to remove any scuffs and polish it at the same time, but this will remove any factory paint. i believe krylon or one of the other brands makes a metal tint paint that is translucent, i have used it to color match amps to cars and it seems to work well. it can be found at just about any napa or other automotive shop and i believe it is intended for wheels, bumpers, etc.
hope this helps,
trin
Nov 08, 2007 | Alpine MRV-F407 Car Audio Amplifier
Car Audio & Video Logo
178 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
