Question about Consew 226R-1
My consew 226R-1
I need to know hoe to adjust the timing between feed dog and needle
  • stitch_shift
    stitch_shift Apr 06, 2012
    The 206 rb1 has a button in the middle of the bed. You hold down the button and turn the wheel backwards and it will reset it. It works on mine but my needle is off center to the left a little.
    Hope this helps stitch_shifter
  • 790 Answers
Hello lilliang ,
You can check out the procedure in ur manual itself in detail!!
Posted on Mar 26, 2008
  • Kanth raj
    Kanth raj Mar 26, 2008
    Increase
    the number of stitches per inch by replacing the Feed
    Eccentrics (stitch cams). Use Eccentrics with a higher
    number. The number on the Stitch Cam represents the
    approximate number of stitches per inch.
    Have a look here
SOURCE:
Consew 226 sewing machine will not feed the material through under the needle
The walking foot lever is not touching the material . is the knee pedal adjusted right . is the manul lever on the back down.
May 11, 2014 | Consew 226R-1
The needle on my consew 225 just goes up and down it seams like in it is not walking. the needle only goes up and down and the fabric stays ther anyone have any ideas??????????????
Regrettably, it sounds as if you may need to see someone who specializes in walking foot Consew machines. I could only guess here and I would have to doubt that anyone untrained could correctly repair it. There are numerous internal mechanisms that drive and time that walking foot to the feed dog, so please do not attempt it yourself. Seek professional assistance.
"it seems like it is not walking" That foot will move in time with the feed dog and if it is functioning correctly, the walking mechanism is quite noticeable and obvious.
Sorry, but if you are asking that question, the only solution past the obvious--you have not lowered the foot--is one that only a professional can correct. Sorry. . .
Sep 11, 2013 | Consew 226R-1
I have a consew 225 I think and when I try to bring the thread up from the bobbin the thread from the needle goes down and around the bobbin to bring up the bobbin thread and catches. It will not pass
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
Jul 18, 2012 | Consew 226R-1
It breaks needles
Put a new needle in. Do not power up the machine. By hand rotate the needle down with the head laying on it's back. With a flashlight watch the needle come through the hole to determine what it is hitting. I've seen (in severe abuse cases) that the needle shaft is bent and the needle hits the bobbin case, instead of just coming down next to it. Use a plyer to carefully bend the shaft back to it's original position. Consew 226R-1 is an excellent machine.
Good Luck!
Feb 08, 2011 | Consew 226R-1
Consew industial machine keeps skipping large areas
remove the front cover around the needle area also you may have to just strip the machine down!! to the hard ware with the bobbin door removed rotate by hand the crank till the neddle goes down to the bobbin area and losen the screws on the bell part of the crank and adjust it till
the needle is dead center and all the way into the bobbin then tighten and reassemble
Jan 14, 2010 | Consew 226R-1
I need to know how to time it. It just sits in one place and sews. It won't feed the material at all. Doing a small braided cord and have to tug it to get it sewn. Tried to raise feet and every thing went...
If the feed dog stays in one position and just moves up and down, and doesn't pull the fabric through, press on the button in the bed closest to the needle bar. Hold it down and rotate the wheel. This adjusts stitch length/feed dog travel. There should be numbers on the wheel or under a flat metal panel next to the wheel. The numbers are for stitches per inch.
The problem you describe isn't timing, it's most likely stitch/feed dog adjustment.
Sep 30, 2009 | Consew 226R-1
Consew 226 breaking needles
I posted an answer to this a couple days ago. If the hook's hitting the needle you need to move it away from the needle. There's a small screw in the bottom of the machine that holds the hook mechanism in place. You need to loosen the screw and gently tap the assembly away from the needle. The hook should just pick up the looped thread as the needle bar rises. You can go to www.consew.com and download a pdf file showing the parts of the machine, also an owners manual. You have to click on the 224 machine. The manual's the same for 224, 225, 226. Or you can click on the 226R-3 - that's the same, too.
Sep 26, 2008 | Consew 226R-1
Thread braking
Check the condition of the top pressure discs and the bobbin case tension. Check for wear in the hook - is the bobbin case seated correctly? Check the tension spring in the bobbin case. I doubt timing has anything to do with the problem. Unless the hook's picking up the top thread a little late, thereby "spearing" the thread. The hook could be catching the thread loop too late. Sounds to me like there's a parts or a small adjustment problem. You don't mention thread or needle size. That's another area of concern at times.
May 22, 2008 | Consew 226R-1
Consew 226R-2
You can download a free PDF file from www.consew.com. There's a complete parts list but you have to click on the 224 to get the 226 manual. It's free - 10 pages!
Aug 31, 2007 | Consew 226R-1
Consew 226R-1 Logo
334 people viewed this question
Top Consew Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
TCHNICAL SUPPORT FOR...
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
