Question about Brother MFC 240C All-In-One InkJet Printer
Print unable 34 on a brother LC-970 - Brother MFC 240C All-In-One InkJet Printer
5 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: Print Unable 34
There might be some paper left in the machine. Check the very edges espacially the left side (seeing from the front).
Another reason could be that the encoder strip isn t in right position or is stained from ink.
Anyway try the first solution first.
If you stll have trouble try to open the printer:
http://www.fixya.com/support/t211210-brother_mfc845cw
and have a close look to the encoder strip + disc (and look out for some paper in the edges... ;-))
Posted on Mar 22, 2008
Mix-it-up
  • 832 Answers
SOURCE: I have a brother LC-51.
and you should get an error 30 which toggles to error 50, i guess.
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
btw: could you plz name modell type next time? Its easier to give hand, though.
Posted on Apr 28, 2008
  • 262 Answers
SOURCE: Brother DCP-560CN unable to print
did any of you three that have the prombelm try going into the files and turnig off all the periously loaded commands ? I bet this is the prombelm, cause the printer only does what it is told and if it is haveing and error message it is beacuse it is tuck in that command of left over printing comands and they haven't been erased yet try and see if this helps and get back to me lala linda
Posted on Jun 03, 2008
  • 32 Answers
SOURCE: brother LC-51 printer - Unable to print 50 error message
If you have the MFC 5460CN this is an easy fix rather than sending it in especialy if your not covered by a warranty. I had the same problem and found the common problem is the inkjet track comes out of place. Make sure your printer is unplugged!!!
If you open the machine up as if your installing the LAN or USB cable you will find that the control panel is held in place by 3 screws, remove those and keep them off to the side or just remember that out of all the screws you remove those are the small ones without the washer.
Next uplug the wires to remove the control panel completely.
Next you want to CAREFULLY or support the lid and remove the slide hinge from the left side of the upper half.
Then remove the cover from the left side and you will find wires, and the cover on the right side and you will find your strip, unplug the wires to pay close attention to where they came from and unscrew the two ground wires.
The upper half should come away from the lower half of the MFC now and all that is left are the bigger screws from the sides, the two in the middle and the 3 screws that were uncovered when you removed the control panel.
If you look closely you will see the inkjet which goes back and forth over the paper to create the image, there is a clear plastic track....if that is not in the groove on the inkjet you are not going to be funcitonal. place the track back into the groove and reinstall all the parts in reverse order and make sure that the upper half fits perfectly onto the lower half, especially pay close attention to the right front of the machines corner where the ink cartridges are installed cause it slides into place.
Once you have it together, if you have an init error look at the wires by the ground wires that have the tiny screw and washer, the multi colored wires and the blue wires may be backwards, switch those around and that should be the end of it all.
This is a very easy machine down to that point, I would not recommend going any further into this machine if the inkjet track is in place.
Posted on Jun 09, 2009
How do I fix this, my printer is printing double letters and showing "unable to print 32"
Print a pic. Scan. Print scan. See if print is wrong. If so, the machine needs re-callibration; machine program should be able to do this.
Oct 17, 2014 | Brother Any 4 Inks Mfc-465cn Mfc465cn...
Unable to print 34 (what is it and how to correct)
This means there may be a paper or object like a paper clip inside the printer. Have you just had a paper jam?
Open the unit and inspect for paper or an object.
Follow the directions in the manual regarding saving any unprinted faxes, then disconnect power for ten seconds. Plug the unit back in. It should be working.
Oct 13, 2014 | Brother Office Equipment & Supplies
While printing out some documents, printe suddenly stopped working and in the screen is show the words Unable to print 34. Never seen it before but need to reair this urgently
Hi
Please check the your USB connection, otherwise u have to change your USB cable and uninstalled the driver, restart your PC, and install the driver again.
May 05, 2011 | Brother Office Equipment & Supplies
Screen showing "unable to print 34"
Brother has a lifetime free tech. support contact them for a resolution
Sep 16, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC-665CW 'unable to print 32 and 34'
This is a error about the head unit! it got problem with moving or lockate a position!Service is the solution for these :)
Aug 20, 2009 | Brother Office Equipment & Supplies
Unable to operate printer when i try it show the message unable print 34
based on research.. Looks like this happens when it's starting up. it goes a short distance and then jams up.
See what could be jamming up the cartridge.
Do you have any specific model information?
http://www.faxpart.com/BROTHER%20ERROR%20CODES%20-%20BY4%20SERIES.htm
Nov 01, 2008 | Brother Office Equipment & Supplies
Print Unable 34
Mar 22, 2008 | Brother Multi-Function Center MFC-240C...
Troubleshooting
So what error message does the machine display except mentioned one?
"Unable to..." and a two digit error code will help us more to understand the malfunktion of the machine
Feb 17, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
100 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
